Results 1 to 6 of 6
Thread: Front Strut bracket bolts
    Mechie3's Avatar
    Manual says to use one front strut bolt and a rear strut bolt in place if the camber bolt. I couldn't find any bolts that were as large as the camber bolt so I bought new OEM rear strut bolts. They're the same size as bts I already had. They all are about 2mm or more smaller diameter than the hole in the knuckle and the strut adapter bracket.
    Is this right?
    Zero Decibel Motorsports
    Is this right?
    Craig,
    Same problem.
    This is what I used from Bell Metric, They all fit tight.
    Bolt, M16X1.5X65 - Hex 10.9
    Washer, M16 - Hardened Flat
    Nut,M16X1.5 - Class 10 Nylock
    Bolt,M14X1.5X60 - Hex 10.9
    Washer, M14 - Hardened Flat
    Nut,M14X1.5 - Class 10 Nylock
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Craig, I had the same issue but I believe my kit had a bigger bolt and nut in the hardware package that wasn't referenced in the instructions. It fit perfectly so that's what I used. Probably the largest nut and bolt in the hardware package.
    Mechie3's Avatar
    Thanks Bob. I cut and pasted the complete product names here for anyone that wants to just copy/paste in the search bar.
    BH16X1.5X65P - Hex bolt 10.9
    NNH16X1.5YLW - Nylock Nut Class 10 Yellow Zinc
    WFHV16YLW - Hardened Flat Washer Yellow Zinc
    Total was $22.31 for 2 bolts, 2 nuts, and 4 washers.
    W machined ours flat and ground out what weld was in the way.
    Mechie3's Avatar
    Did you mean to post this comment here: http://thefactoryfiveforum.com/showt...tting-properly ?
