Results 1 to 7 of 7
Thread: Bolts not sitting properly
    Nov 2015
    I installed the shock mounts on the aluminium lower control arms and one of the bolts sits on top of the weld beads. I'm thinking of changing the bolt to a socket head cap-screw to clear the welds. I'm sure almost everyone has run into this.
    http://imgur.com/c9hdvO4
    Just go with a bolt that fits.
    Tucson, AZ
    My welds were pretty messy on those brackets as well. I did a combination of grinding off some f the flat part on the head of the bolt and grinding down the welds with a dremel. Before I did this, I actually ripped a bolt trying to tighten it down flush, so much better when it actually sits flat.
    May 2013
    Greenbelt, MD
    I used a wheel grinder to take away enough of the weld bead to make the bolt sit flat. I wouldn't go with a smaller bolt head.
    http://thefactoryfiveforum.com/showt...ind#post165339
    Quote Originally Posted by Buzz Skyline View Post
    Same
    Feb 2014
    Asheville, NC
    I took a dremmel to them for the same reason. A little annoying that they didn't sit flat from the factory but an easy fix
    Frank - Build thread
    Mar 2014
    Oakley, CA
    Mine sit flat. I don't remember dremeling them, but I might have. If I did, it was before I got them powdercoated. The cap screw is probably a better solution if yours are already coated.
    Another thing to watch for is how the nut sits on the underside of the aluminum A-arm. Mine did not sit flush, so I counterbored the holes to give the nut a good seat. Probably not necessary, but wouldn't want the bolts to shear from having all the clamping force on one side of the threads.
