Are the JDM parts shop lateral links and trailing link arms good? I'm running the FFR halibrand wheels with a 255/35/18 rear tire on a naturally aspirated car.
I bought some ebay Chinese knock offs. 4 lateral links and 2 trailing arms.
They were C**P. A lot of play in the rode ends.
I ended up using swag tubes with rod ends form Speedway motors and McMasterCarr.
I bought these for $103 on Amazon, and the quality is good. I think I've seen them re-branded for more $$ somewhere since. Also the sway-bar link mounts are bolt on so you can leave them off.
ACDelco 45K0189 Professional Rear Lower Camber Arm
