Results 1 to 3 of 3
Thread: Lateral/Trailing Links
    Nov 2015
    Are the JDM parts shop lateral links and trailing link arms good? I'm running the FFR halibrand wheels with a 255/35/18 rear tire on a naturally aspirated car.
    I bought some ebay Chinese knock offs. 4 lateral links and 2 trailing arms.
    They were C**P. A lot of play in the rode ends.
    I ended up using swag tubes with rod ends form Speedway motors and McMasterCarr.
    Senior Member DSR-3's Avatar
    San Jose, CA
    I bought these for $103 on Amazon, and the quality is good. I think I've seen them re-branded for more $$ somewhere since. Also the sway-bar link mounts are bolt on so you can leave them off.
    ACDelco 45K0189 Professional Rear Lower Camber Arm
