Results 1 to 2 of 2
Thread: OEM Pedalbox Alignment to Frame
    Des Moines, IA
    Has anyone else had issues where the top holes on the pedal box will not align properly with the frame?
    All the front bolts are all the way in, including the ones on the clutch master cylinder. Seems like either the holes on the frame are off, or the pedal box is? Any ideas how to correct other than just drill out the holes to match?
    Senior Member TX-Lou's Avatar
    We actually just did ours yesterday and they looked similar. Everything was in correctly so we just drilled out the holes a little so that the bolts would fit.
    - Lou
    Building an 818C
    Ordered: 8/31/15, Production Date: 1/23/16, Delivery Date: 2/05/2016
    First Start: 4/14/2017
    818C Build Thread
    Donor Teardown Thread
