0
0
OEM Pedalbox Alignment to Frame
Has anyone else had issues where the top holes on the pedal box will not align properly with the frame?
All the front bolts are all the way in, including the ones on the clutch master cylinder. Seems like either the holes on the frame are off, or the pedal box is? Any ideas how to correct other than just drill out the holes to match?
We actually just did ours yesterday and they looked similar. Everything was in correctly so we just drilled out the holes a little so that the bolts would fit.
- Lou
