Bobby Doug
I put in a second spring around the brake cable. It is between the caliper and the lever activating the parking brake. You really cannot tell it is there when using the parking brake. The brake fully releases with the help of the extra spring. I got the idea from EdwardB. I can add a picture if anyone needs to see it.
Doug
please add it if you can. There should be no need for this as the right one works fine. I should know as I have two right ones as they send me one by accident. I've spent hours trying to fix it so it works as designed but am ready to see what you've done. Thanks.
