I can't seem to figure this part out. The FFR Headlight Switch is connected to the RF wiring harness plug. The ON/ON toggle switch is connected to the BRN-HIGH BEAM (side tab toggle) LT BLU-HDLT SW-DIMSW (center tab toggle) RED-LOW BEAM (side tab toggle) then the BRN-HI BEAM IND LT wire is attached to the blue indicator light and the indicator light is grounded. When I pull the Headlight Switch out to the on position the headlights don't come on until I flip the toggle switch. The indicator light never comes on. What am I missing, could it be a bad toggle or a bad Headlight Switch?
FYI everything else works, running lights, blinkers blinker indicator lights, brake light, tag light.
Only the headlights with the high low beam and the indicator aren't working properly.
