Results 1 to 3 of 3
Thread: rear adjustable lower control arm
    OK, maybe a dumb question, but I got the FFR adjustable control arms for the rear suspension. I'm not sure which control arm it replaces. does it replace the front arm or the rear which has the bracket for the rear sway bar links. My donor car was hit near the rear and the arm with the bracket is bent, so I'm hoping I can use the adjustable one in its place.
    Tom
    Quote Originally Posted by tgf05354 View Post
    Tom
    You can use it in the rear for sure. I always buy an extra set and replace all of those bars. Donor ones are usually bent from floor jack damage.
    Thanks for the confirmation. Good to go!
