Thanks Thanks:  4
Page 3 of 3 FirstFirst 123
Results 81 to 116 of 116
Thread: #8938 - Jacob's Build
    DavidW's Avatar
    Stevensville, MD
    Looks great, definitely do all fitting prior to paint. I wasn't confident at the time and regret not going through the process, I left it up to the painter and they did all the fitting and body work.
    Back to your post from July last year, did you end up putting the Fitech O2 sensor in the header, if you could post a pick please do. How do you like the system? I'm thinking about switching over to EFI maybe next year and am looking at MSD and Fitech.
    Jupiter, FL
    Quote Originally Posted by Jacob View Post
    Progress is slow but Iím attempting to mount everything I can think of prior to disassembling for paint. Putting off mounting the windshield for last.
    Attachment 83019
    Attachment 83020
    Hi Jacob,
    I think the windshield should go in prior adjusting the door. It can affect the door overall fitment. I am fitting the body as well now.
    Broku518
    Jacob's Avatar
    Rogers, AR
    Quote Originally Posted by DavidW View Post
    If you look real close on my #56 post on the left you can see where the sensor is on the header. I can get you a better pic. I put the O2 sensor on the header per Gordon Levy,s recommendation. My experience so far with Fitech has been limited to go carts around the neighborhood and infrequent starts, but so far it starts and runs! Based on what I read , some fine tuning / adjustments will be needed after 3-400 Miles.
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Jacob's Avatar
    Rogers, AR
    Hi Jacob,
    Broku518
    Yes I’ve heard that too, and also read where the body should not touch either of the posts? So many horror stories on the windshield, makes me reluctant to touch it...even though I know it’s got to be dealt with!
    Levy 306
    T5
    2015 Mustang IRS
    Jupiter, FL
    That is correct, no touching. Plus, you may need some shims for brackets and frames. They may not lined up, you certainly don't want to create any pressure point there.
    My least favorite part, it requires two people and you don't know if you have a problem until it cracks
    Jacob's Avatar
    Rogers, AR
    I have an assortment of shims and plan on following Edwardb’s method of tapping with 1/2” thread and shimming...plus not letting the body contact the posts...after that?
    Levy 306
    T5
    2015 Mustang IRS
  7. #87
    Mar 2018
    McCall, Idaho
    Nice work Jacob. The vinyl you chose looks great.
  8. #88
    Jupiter, FL
    You should be good to go. You may need to keep in mind the angle/distance, if you plan on doing a soft top. I recall something like 27" measured from front top of the windshield screw to end of the door panel. Either ways, it would be a good practice.
    There are some well documented treads with pictures, https://thefactoryfiveforum.com/show...ghlight=gumbal
  9. #89
    Jacob's Avatar
    Rogers, AR
    Since I installed the IRS by myself, figured I’d go ahead and mount the windshield. Passenger side required more shims than the driver side? Normal? Anyway everything has been assembled and taken off. Installed the mini bear claw latches and now starting to level up the areas around the doors.
    Levy 306
    T5
    2015 Mustang IRS
  10. #90
    Jacob's Avatar
    Rogers, AR
    Still sanding and sanding....
    Levy 306
    T5
    2015 Mustang IRS
  11. #91
    Kearney Nebraska
    Are you going to paint it yourself? (Sorry, if you've already posted the answer)
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018
    Serial #9158
  12. #92
    Jacob's Avatar
    Rogers, AR
    Yep...I’ve painted a few cars, but I’m real slow and deliberate. Always solid colors so I’m waffling between silver and white as primary colors? Besides if I paid the $$$ and got a scratch or chip I’d be sick!
    Levy 306
    T5
    2015 Mustang IRS
  13. #93
    Jacob's Avatar
    Rogers, AR
    Almost have both doors where I’m comfortable with their fit. Probably how I fit the panels beneath both doors, but I’m not liking how much filler I’ve had to use to get the right levels between the door panels and the front and rear posts. Tried to follow the instructions where the pass side is pushed in and the driver side in at the post and out at the rear? Shooting for 3/16” for the gaps.
    Levy 306
    T5
    2015 Mustang IRS
  14. #94
    Jacob's Avatar
    Rogers, AR
    This is my attempt to get the “curl” out of the rear corners of the hood....
    Levy 306
    T5
    2015 Mustang IRS
  15. #95
    Jacob's Avatar
    Rogers, AR
    [ATTACH]85522[/ATTACH
    Got the door gaps, trunk gaps and hood gaps set. Hood scoop and hood cutout set. Plan to take the body off and get ready to start the primer filler stage (slick sand). Arrived at a center line. Had to apply pressure and heat to push down the curl on the ends of the hood. Quite a bit of work to this point! The pressure and heat so work!
    Levy 306
    T5
    2015 Mustang IRS
  16. #96
    Jacob's Avatar
    Rogers, AR
    Took the body off after all the gaps have been set to 3/16”. Also after windshield set, side pipes, headlights,tail lights, hood scoop, basically all holes drilled so that I won’t be messing with a freshly painted body. Will spray slick sand next week.
    Levy 306
    T5
    2015 Mustang IRS
  17. #97
    Jacob's Avatar
    Rogers, AR
    Started applying slick sand today. Trying for three coats on all panels. Hope to spray the body tomorrow!
    Levy 306
    T5
    2015 Mustang IRS
  18. #98
    Jacob's Avatar
    Rogers, AR
    2 Gallons of Slick Sand on
    Didn’t have any issues getting the slick sand on, once I got a gun with a bigger nozzle (2.0). Think another gallon may be needed after block sanding? Sanded a small spot and it impressed me with how smooth the surface was!
    https://thefactoryfiveforum.com/albu...chmentid=86715
    https://thefactoryfiveforum.com/albu...chmentid=86716
    Levy 306
    T5
    2015 Mustang IRS
  19. #99
    Jacob's Avatar
    Rogers, AR
    Currently sanding the slick sand with 150 grit. Plan to spray with one more gallon of reduced slick sand and use 240 grit prior to primer coats. None of this is done very quickly (obvious that painting is a long labor intensive process)!
    Levy 306
    T5
    2015 Mustang IRS
  20. #100
    Jacob's Avatar
    Rogers, AR
    After 3rd gallon of slick sand (overkill I’m sure),sanded with 220 grit. This dry guide coat stuff is great, should anybody be curious?
    Levy 306
    T5
    2015 Mustang IRS
  21. #101
    Jacob's Avatar
    Rogers, AR
    The warm weather and other obligations have slowed me a bit. The 2K primer has been sprayed and now I’ll sand this to 400, then 500 before paint. Color not yet decided?
    Levy 306
    T5
    2015 Mustang IRS
  22. #102
    Jacob's Avatar
    Rogers, AR
    In the last stage of sanding before paint, wet sanding with 600 using a dry guide coat. This is good stuff. Seems like it amplifies the orange peel from the primer, but the surface is smooth as a baby’s butt. Just gently sand until all the low black areas disappear. Doors,trunk,hood and scoop done. Just lack sanding the body.
    Levy 306
    T5
    2015 Mustang IRS
  23. #103
    Jacob's Avatar
    Rogers, AR
    Done with sanding prior to paint, block sanded 2x with 600, used guide coat powder. Plan from here is wait a few weeks for less humidity and cooler temps, then paint. Obviously haven’t worked on the body everyday but as a point of reference, body work started Dec 2017, with a bit of overkill stopped sanding yesterday!
    Levy 306
    T5
    2015 Mustang IRS
  24. #104
    Jacob's Avatar
    Rogers, AR
    Started paint today. Painting doors, hood, trunk and scoop. Wimbledon white with Ford Lightning blue stripes. Pecking order puts the body in the garage while these parts are being painted.
    Levy 306
    T5
    2015 Mustang IRS
  25. #105
    Jacob's Avatar
    Rogers, AR
    Making progress, got the stripes sprayed and masked off, will spray white tomorrow
    Levy 306
    T5
    2015 Mustang IRS
  26. #106
    Jacob's Avatar
    Rogers, AR
    Happy with the stripes , unhappy with the orange peel in the clear (my fault for not better setting up the gun). Plan to let the clear cure for a few days and try to sand off most of the orange peel. No reason to pile up more clear so I stopped after the first coat. The horizontal panels are good?
    Levy 306
    T5
    2015 Mustang IRS
  27. #107
    Jacob's Avatar
    Rogers, AR
    Feeling better after sanding to 3000 and polishing with rubbing compound, should be better after hitting with polishing compound! Sanding took out the orange peel, so for a shade tree painter I’m happy!
    Levy 306
    T5
    2015 Mustang IRS
  28. #108
    Glen Burnie, MD
    Thats looking nice!!
    Plan: 427W-X, TKO600, Moser 3.55 rear.
    Delivered Feb 2017, first start Oct 22, 2017, first go-cart Mar 26, 2018
  29. Thanks Jacob thanked for this post
  30. #109
    Jacob's Avatar
    Rogers, AR
    Cutting and buffing continue, feeling pretty good, but it’s a slow process
    Levy 306
    T5
    2015 Mustang IRS
  31. #110
    Jacob's Avatar
    Rogers, AR
    Sorta feel like I’m over hump now that the body and hood are buffed and polished!
    Levy 306
    T5
    2015 Mustang IRS
  32. #111
    May 2018
    Riverside CT USA
    Nice, Jacob! looks great!
  33. Thanks Jacob thanked for this post
  34. #112
    Senior Member BadAsp427's Avatar
    Summerville, SC
    Really looks nice... great work... When are you going to build the large paint shop out in the back yard and taking orders?
    Mk4 20th Anniversary #8690 ( #8 of 20 )
    Purchased 8/18/18----Build Started 8/19/18
    First Start 11-1-18
    ---- First GoCart 11-7-18
    BluePrint Engines 347ci / TKO600
    Carb / Heater / Heated Seats / Cruise Control / Drop Trunk & Battery
    Build Thread Click Here Gel Coat Driver 1/12/19
  35. Thanks Jacob thanked for this post
  36. #113
    wareaglescott's Avatar
    Looks great. Nice work
  37. Thanks Jacob thanked for this post
  38. #114
    Jacob's Avatar
    Rogers, AR
    Thanks all but....How ‘bout never! At 65...last paint job for me! But I think I said that the last time?
    Levy 306
    T5
    2015 Mustang IRS
  39. #115
    Looks great!
  40. #116
    Jacob's Avatar
    Rogers, AR
    Moving day today! One year and about 10 days todo all the body work and painting! I only have room in my garage for either the body or the chassis, so while I’ve been doing the body work the chassis has been sitting idle. Mention this because I have the Fitech FI system and constantly hear the complaints...well it has sat for 12months...hit it with 2 prime shots and started immediately! Now I can install carpet and other interior stuff.
    Levy 306
    T5
    2015 Mustang IRS
Flat Irons Tuning
