Any recommendations for ebake boots that work with a trans top mounted ebrake? None of the ebay listings have any measurements.
"Loyalty to the country always. Loyalty to the government when it deserves it".
Mark Twain
I have used the FFR supplied one many times in that application. I use on of my trim rings to secure it down and then cut off the excess with a razor.
Thanks, Mike
Mark Twain
You've probably already seen it but ********** sells a boot to fit a top mounted e-brake handle:
https://www.**********accessories.co...top-mount.aspx
I haven't used it but you could call or email someone there to get dimensions if you're curious?
Sean
MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
Hmmmm. That looks interesting, too.
Mark Twain
The ********** boot won't fit my bezel, so I'm down to two alternatives.
I need a part number for the FFR boot since it isn't listed on the parts web page
or
I need to buy one from someone who isn't using theirs.
It seems that I gave mine away thinking I would not need it.
Mark Twain
14922 according to my FFR parts order list.
Mark Twain
I use the lokar boot in most my builds along with their shifter boot.
