Thread: Ebrake boot
    Ebrake boot
    Any recommendations for ebake boots that work with a trans top mounted ebrake? None of the ebay listings have any measurements.
    Mark Twain
    I have used the FFR supplied one many times in that application. I use on of my trim rings to secure it down and then cut off the excess with a razor.
    Thanks, Mike
    Mark Twain
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    You've probably already seen it but ********** sells a boot to fit a top mounted e-brake handle:
    https://www.**********accessories.co...top-mount.aspx
    I haven't used it but you could call or email someone there to get dimensions if you're curious?
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
    Hmmmm. That looks interesting, too.
    Mark Twain
    The ********** boot won't fit my bezel, so I'm down to two alternatives.
    I need a part number for the FFR boot since it isn't listed on the parts web page
    or
    I need to buy one from someone who isn't using theirs.
    It seems that I gave mine away thinking I would not need it.
    Mark Twain
    Senior Member karlos's Avatar
    Aug 2013
    Littleton, CO
    14922 according to my FFR parts order list.
    Mark Twain
    wallace18's Avatar
    Trenton, Florida
    I use the lokar boot in most my builds along with their shifter boot.
