Results 1 to 9 of 9
Thread: Ebrake boot
    Super Moderator oldguy668's Avatar
    Ebrake boot
    Any recommendations for ebake boots that work with a trans top mounted ebrake? None of the ebay listings have any measurements.
    "Loyalty to the country always. Loyalty to the government when it deserves it".
    Mark Twain
    Norton, MA USA earth
    I have used the FFR supplied one many times in that application. I use on of my trim rings to secure it down and then cut off the excess with a razor.
    Thanks, Mike
    Mark Twain
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    You've probably already seen it but ********** sells a boot to fit a top mounted e-brake handle:
    https://www.**********accessories.co...top-mount.aspx
    I haven't used it but you could call or email someone there to get dimensions if you're curious?
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
    Hmmmm. That looks interesting, too.
    Mark Twain
    The ********** boot won't fit my bezel, so I'm down to two alternatives.
    I need a part number for the FFR boot since it isn't listed on the parts web page
    or
    I need to buy one from someone who isn't using theirs.
    It seems that I gave mine away thinking I would not need it.
    Mark Twain
    Senior Member karlos's Avatar
    Littleton, CO
    14922 according to my FFR parts order list.
    Mark Twain
    I use the lokar boot in most my builds along with their shifter boot.
