Thread: Alignment Specs Please
    Brookeville, Maryland
    I purchased an MK 1 back in January and have been tweaking things and just changed the wheels and would like to have the alignment checked. I have looked through the manual and can't find the specs anywhere. The MK 4 manual shows specs but I'm not sure they are the same for my car. I am running 17's. Rear is solid so no issue's there.
    Thanks -
    Tech Support, FFR Brian Z's Avatar
    Wareham MA
    The alignment specs should be the same on the Mk1 and Mk4 cars. If you are running power steering you can run more caster for better road feel. Manual steering should have 3* caster and power steering should have 6*-9* caster.
    Caster 3* (6-9* power steering)
    Camber -1/2*
    Toe 1/16" toe in
    Best regards,
    Brian @ FFR
    Fort Lauderdale Fl.
    brian would this apply to the coupe with power steering also? thanks stevn
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Thanks Brian - I wish it had power steering but I'm used to it now.
    Wareham MA
    With 3* caster the steering might feel twitchy or too easy. Increasing the caster will make the steering wheel want to return to center. 6*-9* of caster would give you more road feel with power steering.
    6*-9* of caster with the manual rack might make it too difficult too steer.
    Brian @ FFR
    Wareham
    Same specs for the coupe as well
    Jim Schenck
    Factory Five Racing
    Fort Lauderdale Fl.
    thanks gents.
    67 427 Cobra
    57' Belair
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Member Dlirium's Avatar
    San Jose, CA
    Old post - checking what the specs are for the Gen III coupe...still the same or updated?
    thx!
    Quote Originally Posted by Dlirium View Post
    thx!
    Interestingly, pretty much the same. Page 523 in the Gen 3 Coupe manual:
    Front
    For a car using a manual steering rack or the power rack without power use the following specifications:
    Caster: 3°
    Camber: -0.5°
    Total Toe: 1/16” in or 0.14° in
    For a car using power steering car use the following specifications:
    Caster: 7°
    Camber: -0.5°
    2015 IRS only
    Camber: -0.5° to -0.75°
    Total Toe: 1/8” Toe in 0.28° in
