FFR drive shaft, new. 1330 Spicer bearings. Yoke for 31 spline TKO, flange for 8.8 Ford, with bolts. $275
From the flat flange (pinion end) to the center of the rear U-joint is 1-5/8 inch (maybe just a sliver less, but real close), and from the center of each U-Joint is 7-1/8. So total from the flat flange to the U-Joint on the transmission yoke end is 8-3/4 inch. The 31 spline collar measures 6 inches from the tip to the forward u-joint center. Total length from tip of the trans collar to pinion flange is 14 3/4 inches.
Reason: added dimensions
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
Sorry, I guess that would be helpful. See top post, I've added it there.
