Thanks Thanks:  19
Likes Likes:  73
Page 15 of 21 FirstFirst ... 51314151617 ... LastLast
Results 561 to 600 of 825
Thread: Making progress on my build...
  1. #561
    Senior Member beeman's Avatar
    Indiana
    Quote Originally Posted by dallas_ View Post
    Looking good. Thanks for the update, I enjoy following your progress.
    Thanks John!
    All done but no adjustments made yet...
    The bulky steel hinge mounts are gone, now just simple studs off the main chassis tubes. With the FFR setup, my hatch would bind up at the corners of the body if I opened it more than maybe 50 degrees. Have about 85 degrees of arc now, limited by the hinge endpoint. Very solid and fluid. Much happier with this setup! No more sloppiness or play in closed position.
    GTM #304 LPE 525hp LS3
  2. Likes LCD Gauges, DSR-3 liked this post
  3. #562
    Indiana
    I'm going to try something...
  4. #563
    Indiana
    I had hoped to do something like this originally, but the FFR hatch hinge and bracket were in the way...
  5. #564
    Senior Member Jkviper's Avatar
    Central Jersey
    Nice job on the brake booster, also enjoying reading through your build thread.
  6. #565
    San Diego
    No issues on the Bel Ray. It costs me more than I sell it for by the time shipping etc. is calculated in. Your source is the cheapest I have seen. I will likely pick some up from them also.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  7. #566
    Dave-
    You are a freaking magician!! I really admire what you are doing, and how you are getting it done!
    Your vision and execution are extraordinary, and I can't wait to see this thing done; but I am sure enjoying the build process, and the ride you are taking us on!!
    Keep up the great work!!
    Newcastle, Wyoming
    What year 350z roadster trunk hinge did you use to make your hinge? Looks good and really increases the hatch opening area.
  9. #568
    Indiana
    Thanks Jkviper, Steve!
    Any of the US spec 350z roadsters/convertible, I think 2004-2008. NOT the coupe/hatchback. It's not plug and play, but really pretty easy to do with some simple welding.
  10. #569
    Dallas county, TX.
    I think I’ll steal that hinge idea.
    update: I just bought a pair from eBay $18 shipped.
  11. #570
    Senior Member Taz Rules's Avatar
    Dec 2012
    BC, Canada
    Loving this.
  12. #571
    Newcastle, Wyoming
    Thanks Dave I have the hatch on now but still not happy with fit so will keep working on it and may change the hinges as the ones you made seem to work great.
  13. #572
    LCD Gauges's Avatar
    Toronto, Ontario
    Damn, you have all the answers for this monster!
    At times I wish I knew all of these solutions before starting my build. It makes me want to redo my car over and over.
    Your hatch contour is pretty much perfect with the roof line.
    Did you modify anything, or was it matched "out of the box"?
  14. #573
    Indiana
    Quote Originally Posted by Procision-Auto View Post
    It didn't match perfectly out of the box. I think you are referring to this picture (I still have not made any adjustments after welding it in, may need to adjust slightly). The 350z hinges really control the position of the hatch leading edge. There is an adjustment screw built into the hinge as well that allows fine-tuning of the closed position. Before I installed the hinge, the driver's side leading edge of the hatch sat about 1/3" higher than it is in this picture. I placed a weight on that corner of the hatch to hold it symmetric to the passenger side of the hatch while I welded the mounting studs for the hinge to the GTM frame (hinge was already bolted to the hatch). Now it knows where to live in the closed position. The FFR hinges didn't have that control of position, too sloppy.
  15. #574
    Dallas county, TX.
    With all the cv and axle work does anyone know a source for the c clips? They have been hard to find.
  16. #575
    Quote Originally Posted by HardRocker View Post
    Yeah, I had the same experience.....here is a thread I started on that:
    https://thefactoryfiveforum.com/show...LE+SPRING+CLIP
    I ended up finding some in a box on the shelf here, so never did try to order any or find them to purchase....
    Shane Vacek
    www.vraptorspeedworks.com
  17. #576
    Dallas county, TX.
    Thanks Shane. That 22727024 part number did the trick.
  18. #577
    Indiana
    OK... Few updates. Life has been busy!
    Homemade front fuse/relay box ready for harness wrap.
    Confirming that the A/C condensor will fit behind the passenger side intake.
    Glassed in the 1/4 windows to match the Honda B-pillars.
  19. #578
    Indiana
    Built up my airbox, almost done. Will make a scoop for the intake (probably 3D printed).
    Kind of a pain building the box to fit the body at the air intake and work around the chassis tube!
    Upgraded the 3D printer, I kept needing to print things that were too big for the build area on the old printer.
  20. #579
    Indiana
    Just about finished up the airbox. Not trying to win any beauty pageants since the outside will be covered with heat shielding.
    Air filter is accessible, the red portion of the airbox will be held in place by screws/rivnuts.
  21. #580
    Indiana
    Quick update.
    Finishing up the wiring.
    Yamaha R1 projectors, but they are switched side-to-side so they had to be cracked open and new beam cutoffs made.
    Done, here's a Pic taken just below the cutoff and just above it.
  22. #581
    Indiana
    Finishing up the spoiler...
  23. #582
    Indiana
    Even back in '94 Honda was using variable resistors to control lighting, wipers, etc. So I'm having to tear switches apart and jump the internals to dumb them down a little.
    I wired up the turn signals to a standard flasher relay and FYI for you guys planning on running LED lights on the corners, the LEDs don't draw enough current to make the flasher relay even work. Ordered some flasher relays designed for the low draw of LEDs:
    https://www.amazon.com/dp/B011BTMDQM..._1.O4DbN6JQ5QG
  24. Likes rolfer liked this post
  25. #583
    San Diego
    All you need to do is put a resistor across the LED leads to increase the draw when in use. The LED specific flashers are the official way to do it, but the resistors are the cheap and easy way to do it.
    www.myraceshop.com
    GTM solution kits
  26. #584
    Beeman,
    here is a link to the load resistors that I used, for the led turn signal lights that were supplied by FFR.
    https://www.superbrightleds.com/more...g-fix/190/831/
    Central Jersey
    I had to move the foot box forward and create a new firewall. I utilized 1/8" steel plate for the firewall. I incorporated modified Toyota pedals, converted from OEM hanging style to floor mounted. Utilizing C5 Corvette brake booster/master cylinder, Toyota 5/8" clutch master cylinder, Corvette fly by wire gas pedal converted to floor mounted. Driver footbox extended with sheetmetal into tunnel area, cooling lines will run outside the car similar to the 818.
    Clutch pedal converted to floor mount
    Corvette booster with shortened piston rod, fashioned a 1/2" aluminum spacer.
    Dave,
    What are your thoughts on adjusting brake bias? You and I have a similar setup to our mid engine kits and I am not sure if I will need to add a proportioning valve to either the front or the rear brakes or both to dial it in. Curious what you are thinking.
    Joel
  28. #586
    Indiana
    Thanks Mike and Steve.
    Dave,
    Joel
    Joel, are you running ABS? I'm running the OEM C5 ABS/EBCM so I'm not so concerned about front or rear lock-up, but there still may be some imbalance under track conditions. I looked through some of the C5 forums and usually guys are changing calipers to get more braking from the rear. Some of the C5 Track guys have ripped out the ABS and went with a Tilton/Wilwood setup. I don't think a variable proportioning valve is a great option in my situation as it would probably screw with the EBCM. I'm wanting the best option for street + track. Track only, I would probably ditch the ABS and booster entirely.
  29. #587
    Central Jersey
    No ABS, no track and the stock Gen V Camaro dual Master Cylinder(1” bore) with Gen 5 Camaro SS calipers. The stock Tilton master cylinders are 3/4” front and 7/8” rear so if my math is correct this setup sends 16% more pressure to the rear calipers. So my thinking is to maybe put the proportion valve on the front brakes and that way I could create similar balance.
    I have’t put much thought beyond that, but thought I’d ask since we are following similar paths.
  30. #588
    Quote Originally Posted by Jkviper View Post
    With the larger MC on the rear brakes, that should make less pressure than the fronts......more fluid flow, less pressure. You would have to go to smaller MC size to increase pressure.....
    Shane Vacek
  31. #589
    Central Jersey
    Thanks so much Shane for adding your input. i’m Glad I have it backward, now it makes more sense with what I would need to do to get good brake balance. Dave, didn’t mean to hijack your thread and appreciate your feedback as well.
  32. #590
    Indiana
    I'm pretty proud of my redneck 8 channel wireless steering wheel button system!
    Lots of tedious soldering...
  33. Likes Jkviper liked this post
  34. #591
    Indiana
    Continuing to mock up the console... I wouldn't dare build a C5 based kit without a manly DIC!
  35. Likes Jkviper liked this post
  36. #592
    Member kabacj's Avatar
    If you are considering tuning the GTM for the track
    The proportioning setup from willwood is required.
    I has stop tech custom build the calipers to match the weight bias and traction of the GTM. Even so the ability to adjust the bias really changes the turn in.
    On the street it doesn’t matter at all. The GTM has so much extra braking capacity it’s silly.
    On the track some form of bias adjustment is a must have.
    The C5 although using the same components doesn’t drive anything like a GTM on the track. It’s apples and pineapples.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
  37. #593
    Nice job man. Are you milling or printing those components?
    XTF #2
    GTM # 344
  38. #594
    Indiana
    3D printing. Prototypes in PLA, final components will be carbon fiber reinforced nylon. How's your track car? Any updates?
  39. #595
    Very cool. Yeah I’ve been busy updating my capabilities in the shop for the next phase of development. I need some robots to help me get the job done. Updates are coming soon.
    XTF #2
    GTM # 344
  40. #596
    Jul 2014
    The redneck setup looks pretty sharp to me!!! Nice work
  41. #597
    Indiana
    I'm naming this mod "The GTM can be a Grand Tourer".
    I was privileged to have the guy who built the exhaust for this out to my shop a few days ago.
    He's going to make sure the exhaust routing works for the modification. On my end, it begins by narrowing the gearbox subframe so that the luggage compartments are accessible.
    Can any of you mathematicians tell me how much shop space I lost to the 15' trampoline?
  42. #598
    Jul 2014
    Apparently not enough space to hamper your build LOL. Maybe one day I’ll have a shop big enough to fit my build(s) and and trampoline
  43. #599
    Indiana
    Time for the diffuser. Well, I've been studying this book
    The Gen1 diffuser measures almost 30 degrees which certainly does not work. Unfortunately it's a single unit so the angle can only be changed by cutting it.
    Edit : that's better. The underside (that you don't want the airflow to detach from) is very rough. I'll sand it down and clear coat it to make an air-friendly surface. If you install per manual, do not consider the diffuser as more than a cosmetic piece. Which is fine, of course, for street cars that don't exceed speed limits by too much.
  44. #600
    Indiana
    So here's what 10 degrees looks like at ride height (4.75" at rear of main chassis tube). My rear 'bumper" might be slightly higher or lower than FFR design due to my mods. 7 degrees of diffuser angle is what most say is safe for a functional diffuser without wind tunnel work and without assistive aero devices (ie a rear wing). 10 degrees should be safe with a spoiler or wing, maybe even 15 degrees with a wing. At 10 degrees, there is about 20mm of clearance to the ground at the edges of the diffuser so it would need trimmed for street use, probably even for track use. I'm thinking that the best option would be 2 diffuser angles, easily switched, with around 10 degrees for the track and a higher angle for the street where efficiency is not a concern for the most part.
    Now it's starting to look like a functional diffuser. These guys are running the highest angles they can to maximize downforce, so you can see where they found the limit even with big wings...
    Again, here's me at 10 degrees.
  45. Likes RR46 liked this post
