Thanks Thanks:  19
Likes Likes:  73
Page 11 of 21 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 825
Thread: Making progress on my build...
  1. #401
    Bee-
    I have been following along with your build for quite a while now, and I have really enjoyed following your progress. I know I have said before how much I admire your craftsmanship, your creativity, and your ability to stick with it despite several serious challenges. However, I need to say it again! I remain amazed at what you have done by tearing apart a GTM kit, adding bits and pieces of other cars, plus a great deal of creativity and problem solving, to make an amazing car! She's a Frankencar (and I mean that in a very good way!), but a stunning Frankencar, and I can't wait to see what she will look like when you are done with your magic!!
    Thanks again for allowing us to follow along on your awesome build. Mad skills brother, mad skills!!
    All the best!
    Aug 2018
    Chicago
    Bee-
    All the best!
    +1. I check this thread daily for every bit of the glorious automotive engineering porn. Bee your build is a real treat to follow!
  3. #403
    Senior Member beeman's Avatar
    Indiana
    Thanks, guys. One of my favorite things on this forum is watching the other builds come along as well.
    Thanks for all the input on the other thread about mounting hinges to the fiberglass.
    As much as I like the idea of aluminum or composite, I think steel is the best option in my hands. I cut some rectangles out of 1/16" sheet, they are actually lightweight as small as they are. Welded in some studs to match the hinge mount. Will drill some holes to help the bonding agent bite then etch prime them. Then localize them with clecos as suggested, then bond and fiberglass them on.
    Front and back sides of the plates
    GTM #304 LPE 525hp LS3
  4. #404
    Indiana
    Carbon fiber prop rod, full trunk/suspension/maintenance access! Yea! I don't know if I mentioned it, but I almost chickened out and went with 4 hood pins and no hinge, very glad I took the time to do it right.
    Not the best video, propped the phone on the welder, but you get the idea...
  5. Likes LCD Gauges liked this post
  6. #405
    Senior Member dallas_'s Avatar
    Dallas, TX
    Isn't it about time for an update??
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
  7. #406
    Indiana
    Ok, hopefully it's not a boring update, but here goes!
    Figured I'd goof around with the gauge cluster a little, Plan B is Tino's LCD cluster, but my narrow Honda cluster would force me to use a small LCD if I go that route.
    Honda dashboard/gauge housing, Corvette C5 gauges. Lot less real estate in the Honda housing.
    Pulled the Honda gauge bezel, popped it on the scanner, then imported into the CAD program. All I needed was the outline to 3D print a new bezel that would fit right into the Honda housing, so just traced the outline. (I upload pics at a low resolution to make viewing easier, the pics don't show it but it is a perfect copy)
    Measured the 5 gauges I would be incorporating (no Speedometer, going with a GPS base speedometer outside of the gauge cluster) and decided how to lay it out. To fit a shift light and make things symmetric, I am rotating the tachometer to a flat position compared to the canted C5 position. I'm either going to create a new tach gauge face or leave the RPM numbers canted, it won't bother me. Already have EL gauge faces that don't have Corvette logos on them.
    Added the shift light slot plus indicator light locations. Had to divide in half for printing, on the printer now. Will do a carbon fiber overlay on the ABS shroud.
  8. #407
    Dallas, TX
    Very cool. Looking forward to seeing the gauges in it.
  9. #408
    LCD Gauges's Avatar
    Toronto, Ontario
    That is pretty cool. What 3D printer do you have?
    P.S. Who is Tito?
  10. #409
    Indiana
    Quote Originally Posted by Procision-Auto View Post
    P.S. Who is Tito?
    An American Icon! Or at least an American Icon's brother... Sorry I must have been in a hurry.
    My printer is an older one, made by XYZ, I think it is about 4-5 years old, paid around $500 back then. Print bed is 8"x8", it has been very reliable.
  11. #410
    Indiana
    Quick update. Printed gauge bezel didn't meet my standards, so I contacted Shane at vraptorspeedworks. He was able to plasma cut my design from aluminum for a very reasonable price. I am thrilled with the result. If anyone is interested, I can do a write up sometime about going from a vision to CAD to Shane's plasma cutter. I'm definitely going to have my center console created by him here soon. It's a great way to achieve perfect symmetry and sub-mm precision. It dropped right into my housing and perfectly matches the gauge face diameters.
    I 3D printed the small gauge supports. Still a little work to do but coming along nicely.
    Here's full resolution photo. Have replacement Electroluminescent gauge faces.
  12. #411
    Bee-
    Very nicely done! I really like how the tach is lying on its side in the center gauge; seriously cool looking!
    I am going to have to get Shane to do some cutting for me too. I have been scratching my head on a few things, and this might be the best answer. Thanks for sharing some of the details.
    Keep up the good work brother!
    Indiana
    Thanks, Steve! Just another way to skin this cat.
    Borrowed my wife's label maker. Getting rid of the bloated C5 power distribution.
    Rat nest!
  14. #413
    Dallas, TX
    That looks sweet. Nice work (as usual).
  15. #414
    That's looking sweet!
    And yes, as Beeman mentioned.....if you need anything plasma cut, I can do that for you very reasonably if you can provide me with a workable dxf drawing of the part you want cut. I can also do the design/CAD work for you, but that will increase the costs substantially since it is the CAD drawing that takes the most time to do. If you need some CAD software, I use the free download from emachineshop.com to do all of my CAD drawing.
    Shane Vacek
    www.vraptorspeedworks.com
  16. Likes rolfer liked this post
  17. #415
    Indiana
    I've become very intimate with the Corvette electrical system
    My Mustang donor had a fuel inertia cutoff switch that I incorporated into my cobra build. Corvette does not have this failsafe. So I purchased a Mustang unit to splice into the fuel pump power wire. I think a good $16 investment, I think everyone should at least consider it. I will say that I will be mounting it within reach in my cockpit, I will admit that I have triggered my cobra fuel cutoff on the track with high g cornering. No fun to wave the corner worker over to reset it in my trunk...
  18. #416
    Dallas, TX
    Beeman, I think a fuel cutoff is absolutely essential. I thought the LS ECU incorporated a fuel cutoff to the fuel pumps?
  19. #417
    Indiana
    There is no inertia cutoff. The PCM does control the fuel pump and apparently will eventually kill power to the fuel pump if the engine dies. That's potentially more spraying fuel than I want.
  20. #418
    LCD Gauges's Avatar
    Toronto, Ontario
    Hmmm...
    Would be easy to program that into a certain system () using accelerometer info: impact forces, fuel pressure, and "shiny side Up" data! Would be nice to have an automated kill switch in the event the driver
    goes 'lights out' momentarily.
    EDIT: Sorry, just saw you purchase a switch up above.
  21. #419
    Indiana
    The EL tach, just like the Corvette, has indicator lights that show through the gauge face, this looks really bad cocked to the side. So I cut a piece of carbon vinyl to cover the indicators. I really like the way the EL tach looks, but I'm not sure how to adhere it to the Corvette face where it won't lift on a hot day - any suggestions? If it lifts at all, it binds up the gauge needle. My 2nd issue is that I would need some way to illuminate the needle, it's pretty much invisible in the dark.
  22. #420
    LCD Gauges's Avatar
    Toronto, Ontario
    That looks pretty good! Is there any way to rotate the numbers and get decent illumination?
    Maybe remove some of the opaque material from the lower layer, and use the top mask to edge the lighting of the numbers?
  23. #421
    Indiana
    The graphics on the EL faces are fixed and extend through the full thickness of the face, I guess they call it 'reverse glow'. So I can't really modify the face.
    Here's what the back side looks like
  24. #422
    Jul 2014
    I haven't checked in on your build for a bit, but had a vacation day today, so now I'm all caught up. Excellent work as usual!!!
    I like the idea of a fuel cutoff in the unfortunate circumstance of an "event." I need to see if I can program this in my "safety" pages in my AEM setup.
    I'm just starting to work my wiring diagram for the entire car, including the AEM system I'm going with in Visio Professional. Fortunately enough I had a good reason to get it on my work computer so I don't have to pay for it. It's a bit overwhelming to learn something new, but I think the final product will be very helpful. It will be a lot of copying what AEM already provides for the ECM, but there are open circuits for additional sensors that I will be using most of. This will allow me to tear apart the AEM wiring harness, add what I need, and make it fit the GTM layout. Plus having an entire wiring diagram before I start will be massively helpful.
    Keep up the great work!!!!
  25. #423
    Indiana
    The Ford fuel cutoff I showed above is completely mechanical so you can use it in any car with an electric fuel pump. You wouldn't even need to let your computer know it's there, just splice into the fuel pump power. If it's ever triggered, the engine would simply behave the same as if you ran out of gas.
    I've heard of people retrofitting these into cars that lack that safety feature.
  26. Likes LCD Gauges, rolfer liked this post
  27. #424
    LCD Gauges's Avatar
    Toronto, Ontario
    I see, that's a difficult illumination to modify.
  28. #425
    Indiana
    By uncovering the illuminated center part of the tach face, more light is available to light up the needle. It's not as bright as oem, but it is functional. I won't be doing much hard driving after the sun goes down, plus my shift light will always be running.
    Got the indicator lights soldered up.
    Got the Electroluminescent gauge faces installed
    Just about ready to install.
  29. #426
    Nice!!!
    Shane Vacek
  30. #427
    Bee-
    Have you considered photo-luminescent paint on the needle? I have seen it used, with varying degrees of success, in a number of places. I think it might at least help with your needle, although I don't think it will make it OEM bright. However, it might be worth a shot.
    I hope this helps...
    Indiana
    Bee-
    I actually thought about doing something like that to the needles, but I will warn anyone NOT to try to remove the Corvette C5 gauge needles, it ruins the gauge. I used my speedometer as a guinea pig, trying to pry off the needle ripped the guts out of the gauge and ruined it. The above EL faces did not require needle removal, probably for that reason. So I don't think I could get a clean paint job on the needles since they are not removable.
  32. #429
    Aug 2018
    Chicago
    Have you considered sliding a laminated postcard or some aluminum foil behind the needle and painting it as is? You can choose a paint that illuminates in UV light and throw a few UV LEDs at the top of the cluster area to provide illumination at night without harming your night vision. Think blacklight on neon paint.
  33. #430
    Indiana
    Quote Originally Posted by Jake From State Farm View Post
    I'll see if I can find an example of that. Paint with brush or aerosol?
  34. #431
    Aug 2018
    Chicago
    I haven’t seen it done before. That’s what I’d try, with a sacrificial part first. Aerosol is usually a better finish.
  35. #432
    Indiana
    Ha, I feel kind of stupid. I just recalled that the OEM needles and faces in the C5 are illuminated by a pair of UV lights that sit in front of the faces on either side of the cluster. I knew this at one point... Duh!!! I confirmed on my C5 in the garage that,
    Yes, the needles themselves illuminate brightly under the UV lights. I ordered some UV led bulbs. I think problem solved. Thanks again for the recommendation.
  36. #433
    Aug 2018
    Chicago
    Derp derp. Happens to the best of us!
  37. #434
    Indiana
    Coming back around to a previous project.
    Had a beautiful spring day today, spent some time in the shop. Hope to have this thing fully wired and running soon.
  38. #435
    Newcastle, Wyoming
    Wiring always just short of nightmare, I see you labeled everything..... I did the same thing, invested in machine to make labels as I will never remember where all those wires went a year from now when I need to take something apart. Good luck with your wiring, always looks like rats nest until they are all terminated and tied up....
  39. #436
    Awesome thread
  40. #437
    Jul 2014
    Hey Dave,
    I like the layout of your steering wheel plate. I wanted to do something little different lately, so I'm kicking around ideas of what I would like mine to look like. I'm thinking two rotary dial switches to control my traction control and either my launch control RPM or blended tunes for track vs. street.
    Whats your plan on running wiring for all those buttons?
  41. #438
    Indiana
    Quote Originally Posted by Shoeless View Post
    Hey Dave,
    Well, here's a thread I made a few years back. I'm currently trying to come up with a wireless option for my removable wheel, but if you are doing rotary switches that would get complicated. If you have a fixed wheel, I'd go with a clockspring setup.
    https://www.ffcars.com/forums/42-fac...on-thread.html
    If you want to go that route, I will give you a good deal on the Momo C5 adapter with the Caddy clockspring. I switched to an electric power column so I had to buy a different hub adapter.
  42. #439
    Caldwell (near Boise) Idaho
    ...I'm currently trying to come up with a wireless option for my removable wheel...
    Check out Raptor Pro. https://www.demon-tweeks.com/us/summ...system-851896/
  43. #440
    Indiana
    Quote Originally Posted by Roger Reid View Post
    Thanks for the link, Roger. I have seen that product and it looks awesome. It is definitely an option if my DIY system crashes and burns. I'll post more as my frankenstein wireless system comes along.
