Thanks Thanks:  19
Likes Likes:  73
Page 4 of 21 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 825
Thread: Making progress on my build...
  1. #121
    Dallas, TX
    Forgot to mention, finalized plans with LPE for a 525hp LS3.
    Oh yeah!
    I'm putting one of those in my SLC.
    SL-C, LS3 525, Mendeola SDR5,
  2. #122
    Senior Member beeman's Avatar
    Indiana
    Next milestone will be getting the door hinges done. Not an easy task. Hard to hinge a door when there is nowhere to mount a hinge. Hard to hang a door on a single hinge and make it stable. Hard to get the arc of swing perfect through trial and error.
    So I brought some chassis tubing out from the frame, it will be strong enough to support the door. I cut up the FFR GTM door hinges which worked in theory but is too flexible, have some wobble in the door.
    Just ordered a couple of dump door hinges, these things look super robust. Had ordered some bullet hinges but they didn't seem like the answer.
    GTM #304 LPE 525hp LS3
  3. #123
    Dallas, TX
    Love the innovation. Very creative way to solve the issue. You an engineer by trade?
    Oh, and it looks like you'll be more like 2,000:1 on this project.
  4. #124
    Indiana
    I wish I had some engineering classes under my belt, my major was Biology! I think this door hinge thing will be one of the most difficult parts of the project, but I'm making gains on it.
  5. #125
    Indiana
    Not much free time lately, hope everyone had a happy Easter.
    Door hinges are backordered till early May they are saying. I haven't found a design from another source that I like, other options are smaller and are bushing-less designs.
    Nice to have LPE guy on speed dial, coolant flow direction verified, leaves engine at water pump above, returns through thermostat below. All sorts of misinformation on the Corvette forums. Didn't guess that, not sure build manual has that right either. After buying an aftermarket Jeep Cherokee aluminum radiator, probably going back to C5 for the surface area. Started mocking it up. Going to run the hard lines outside of the chassis, don't want to build a sauna.
  6. #126
    Indiana
  7. #127
    Indiana
    Modified door trailing edge location marked
    And cut
    Am I the only one thinking this overhang is asking for a McLaren-esque hidden door release button?
  8. #128
    Dallas, TX
    Wow, that is a significant difference.
    Nothing your sawzall can't handle.
  9. #129
    Oct 2014
    Southern Pines, NC
    great work bee man, keep the updates coming!
  10. #130
    Indiana
    Initial door gap set
    Ordered a 16" Spal fan... Received a 12" fan in a 16" box
    Went with straight blades. Little noisier but more efficient. Figured I'd just be hearing the engine anyways.
  11. #131
    Indiana
  12. #132
    Senior Member Roger Reid's Avatar
    Caldwell (near Boise) Idaho
    What motor did you decide on?
    Just an old man with a great hobby
  13. #133
    Indiana
    Quote Originally Posted by Roger Reid View Post
    LPE LS3 @ 525hp. They have a 550hp but I wanted a little lower compression.
  14. #134
    Dallas, TX
    Progress!
    What are you thinking for the door handles? Move the whole opening, or keep it 1/2 on the door and 1/2 on the rear clip?
  15. #135
    Indiana
    I just had an epiphany. Tell me what you think. I don't like how far the front wheel vents extend onto the door now that it's moved forward. Plus I'm not convinced that it's the most efficient way to get air out of the arch. Plus it probably shoots puddles onto the door? Oh, and simpler bodywork there.
    So unless someone can talk me out of it, I'm going to delete the front vents and bring the air out of the arch closer to its source (the tire of course).
  16. #136
    Indiana
    Quote Originally Posted by dallas_ View Post
    Progress!
    Going to delete that handle cutout, probably go with something hidden under the body ledge at the top of the door.
  17. #137
    LCD Gauges's Avatar
    Toronto, Ontario
    I can't begin to get my head around the door modifications. I'm having a tough enough time
    getting things to line up without adding a foreign structure.
    The overall shape is starting to come alive! Lookin' good!
  18. #138
    Dallas, TX
    I like it.
  19. #139
    Indiana
    I like it.
    Then that's how it shall be!
    Actually, I walked around the side of the car many times. It's difficult to capture the changes in pictures. I really like the front vent delete. Every change I make reminds me of a car, this reminds me of a 918 with a flatter wheel arch. Doesn't throw off the front to rear flow at all, I think it actually improves it. Nice transition into the big rear scoop.
  20. #140
    Indiana
    Got the door trimmed to eliminate front vent.
    Don't care for the unibody construction. Should be able to eliminate most of the sheet metal. Just getting started here.
    Power window regulator /motor mounts..
    Tacked together
  21. #141
    Dallas, TX
    Nice. I love what you are doing, and enjoy following your progress and solutions to issues as they crop up. Keep posting!
  22. #142
    Indiana
    Thanks Dallas. Really wanted a decent side impact bar that I could tie into the hinge and latch. Just about done, need to trim and finish welds. Then remove the donor steel. I don't have a bender for square stock, so I used a notch-bend-weld technique.
  23. #143
    Indiana
    99 parts function, 1 part abstract art
  24. #144
    Indiana
    Driver's door done.
    16.4 pounds. Not bad, may add a 2nd impact bar...
  25. #145
    Indiana
    Window mechanicals work (with a little metal trimming)!
    Unfortunately, like about everything else on this car, I have to build 2!
  26. #146
    Indiana
    The del sol is a decent looking little car, but I think the vertical height of the door windows is too tall. Bringing my roof down and the bodywork up about 3 inches, my windows will have more of a chopped appearance which looks a lot sportier. Here's the door panel moved up about 3 inches to the new position to match the external bodywork.
  27. #147
    Dallas, TX
    Um.... what is that and what does it mean?
  28. #148
    Indiana
    Sorry, digital scale, 16.4 pounds before window/mechanism.
  29. #149
    Oct 2014
    Southern Pines, NC
    as always, great updates and always enjoy seeing the progress and watching it slowly come together.
  30. #150
    Indiana
    Lots of time off for baseball /softball /vacation.
    I realized that custom butterfly doors are not conducive to getting this car built any time soon. Not that I didn't have it basically done, I had bad thoughts about making both sides symmetric so it didn't look 'off' with both doors open, etc. May take it on in the future. So C5 donor hinge, C5 latch mechanism. Went up to 1.5" round tube door bar.
    Approximate location of coolant pipes
  31. #151
    Indiana
    Cleco supply running dangerously low!
    I ordered 1" (front) and 2" (rear) fiberglass fender flares, should be here next week. Should eliminate the wheel well asymmetry issues and I think they will look good...
  32. #152
    Indiana
    Fiberglass dust... Yum!
  33. #153
    LCD Gauges's Avatar
    Toronto, Ontario
    You're a smart man! My doors are not gapped and the windows are not installed yet. At this pace, I figure another decade before the
    doors are complete. :/
    Moving the coolant pipes to the side skirts is going to be a major benefit for interior cooling. If I could redo my build, this would be
    very high on my things to do.
  34. #154
    Indiana
    Thanks for understanding, Tino... Wasn't an easy decision to make, but oh well... Not a do or die feature for me, just thought it would be fun.
    Got a couple/few layers of cloth/resin on to tie the new door together, will see how it turns out in the morning
  35. #155
    Indiana
    Building up the backside
  36. #156
    Indiana
    New door with front wheel vent delete. Door skin weighs 6.6lbs.
  37. #157
    Indiana
    Door back on the frame, will bond aluminum angle to the skin to bolt to the door frame. Here's the rough idea for the front fender vent.
  38. #158
    Indiana
    To attach the door skin to the frame, I am planning on using about 10 pieces of bent aluminum sheet, bond to the skin and bolt to the frame. Anyone see any issues with that plan?
  39. #159
    San Diego
    Unless you have a reason to believe you will need to separate the frame from the door skin, just glass over the frame and make them one. That's what we did and it avoids any points of heightened stress. These can cause wrinkles in the door skin and also lead to cracks and failure. The glassed in frame has worked extremely well now for us for YEARS.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  40. #160
    Indiana
    Thanks for the reply Mike.
    Maybe I'll go that route instead. I was a little concerned about rigidity... I shouldn't have to remove the skin, worst case I can just cut it off.
    What would you do in the areas where the frame is up to 4" away from the skin?
    Maybe I'll rivet the angled alum sheet to the frame (in the pic above), then glass it all together for a little more strength?
