Thanks Thanks:  19
Likes Likes:  71
Page 9 of 21 FirstFirst ... 789101119 ... LastLast
Results 321 to 360 of 821
Thread: Making progress on my build...
  1. #321
    Beeman, do enjoy your thread as well as seeing the changes that you are making. You are very skilled in my opinion, and you help keep me motivated to work on my car as well.
    keep it up.
    Senior Member beeman's Avatar
    Indiana
    I agree that seeing other guys moving along motivates me too. I'll try to keep plowing along!
    Adjusted the outflow ducting to protect the radiator from tire debris and airflow disruption. Here's a pic at full lock. Will add a partial protective mesh or screen in the small area that's still at risk.
    Still need to trim a couple edges, but looks about done. Recommended radiator outflow ducting area is 25% of radiator surface area. I'm at 27%.
    GTM #304 LPE 525hp LS3
  3. #323
    Indiana
    The small gaps will have weatherstripping. Should be efficient and aerodynamic.
  4. #324
    LCD Gauges's Avatar
    Toronto, Ontario
    This thing is starting to take shape - very cool! Not that I have to remind you, but you accounted for suspension travel (up & down)
    when checking your clearance correct?
    I like that double rad setup; I think you and Dave are the only GTM's on this site with that feature?
  5. #325
    Indiana
    Quote Originally Posted by Procision-Auto View Post
    Yes, sir. I have about 20mm of clearance minimum at all steering angles and suspension travel. Here's a pic I found that gives you an idea of the clearance. Edit: looking at the pic, I think that I bent the rear edge of that side piece in giving me even more clearance than the picture shows, I'll try to remember to take another.
    Dave Fraser is the only other twin-radiator builder that I'm aware of. And he was very helpful with questions I had. And he's pretty handy with aluminum TIG as well
  6. #326
    Indiana
    Still going to have a front trunk, but the fixed front fenders were not giving me good vibes about front suspension access. So will have a fixed front fascia/forward part of wheel arch, tilting hood with attached fenders. Along the lines of a Koenigsegg Regera but with a forward tilting hood.
  7. #327
    Indiana
    Not much traffic on here so I'll post a small update...
    Honda turn signal /wiper stalks, GM column, so the Honda unit was free floating. Easy fix with the printer.
    Time to get the front finished
  8. #328
    Indiana
    Got a little sidetracked
  9. #329
    Indiana
    Side project about done.. Any guesses?
  10. #330
    I would say looks like harness bar, but not really thinking that is correct.
  11. #331
    Dallas, TX
    I have no idea, but whoever you strap into that isn't getting out.
    SL-C, LS3 525, Mendeola SDR5,
  12. #332
    Indiana
    Ha, it IS a harness bar but I would never trust my life to it!
    A clue : looking forward to the Nurburgring!
  13. #333
    San Diego Ca 92106
    Ha, it's for your race simulator.
  14. #334
    Indiana
    You got it! Voyage to my basement for final assembly! The harness isn't just for eye candy
  15. #335
    Indiana
    Full motion, VR. Should be fun
  16. #336
    Jul 2014
    Now that looks like fun!!!!
  17. #337
    Dallas, TX
    Sheesh..... now you've gotten me interested in racing simulators.
    Wouldja just get back to building your car please?
  18. #338
    Indiana
    Quote Originally Posted by dallas_ View Post
    Don't build one if you can't discipline yourself to stay away from it! Lots of setting up, so far I've driven a 427 Cobra in Belgium. With VR headset, force feedback wheel, Fanatec pedals, and motion seat it's weird taking the headset off and finding out I'm still in the basement!
    Had a seat upholsterer come by to modify my seats to sit lower.
    Time to get the nervous system put in...
  19. #339
    Indiana
    Shifter cables should be here tomorrow from CMS.
    Figured I'd get the hood bonded together, so I can cut it up again!
  20. #340
    Indiana
    Shifter cables done, feels great!
  21. #341
    Indiana
    Finally got the front end glassed together. I found that the cheap $.99 'survival blankets' from Walmart work well for a liner on the table for wetting out the fiberglass and protecting surfaces on the car. Kind of a foil, more of a mylar? Cheap, durable, and very large.
  22. #342
    Indiana
    Getting ready to run coolant hard pipes outside the cockpit. So it will be a ton easier to do each side in 2 segments with a small coupler somewhere along the side of the chassis, otherwise there will be some very complex bending going on. Anyone see any issues with 2 segments instead of one? Would probably be more resistant to vibration damage as well?
  23. #343
    You're Getting There, One Itchy Fiberglass Layout At A Time!
    Good Luck!
  24. #344
    Dallas, TX
    No problem at all with that.
    Good progress!
  25. #345
    San Diego
    As I think you discovered, the only way to bend thin wall aluminum tubing is with a mandrel bender. We buy pre bent sections and then weld them together. Your aluminum welding skills have to be pretty sharp to get no leaks, but it is really the only practical way to do hard piping bends unless you happen to have or know of someone close to you that has a mandrel bender. Many times we will try and just use straight sections of hard tube and then use silicone elbows where bends are needed. An added bonus is that with this method, since we go to the track regularly, it is much easier to carry spares and to do repairs with the straight tube and silicone elbow method.
    For those that do not know what a "mandrel bender" is, it differs from a regular tubing bender in that it has a mandrel that goes INSIDE the tube and essentially provides a dolly for the inside of the material while it is being bent to insure no kinking or deformation during bending. The poor mans way of doing this is to pack the tube with sand, weld the ends shut, then bend the tube and the sand will not allow for a change in volume, thus helping control any kinking or deformation. Again, just not very practical if you want the project done in a reasonable amount of time.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  26. #346
    Indiana
    Yeah, I tried on my JD2 tube bender, went very slow, lubed with white lithium, outside looked perfect, inside bend was all jacked up...
    I'm using off the shelf oem type rubber hoses, do you think it's worth upgrading to silicone?
  27. #347
    San Diego
    As long as you are running a 15 lbs cooling system or less, the rubber hoses should be fine. Also, since you have a pretty custom setup with lots of connections, I think even if I was eventually going to go silicone, if I was you I would build everything out of rubber first as any "redos" along the way will be much cheaper.
    www.myraceshop.com
    GTM solution kits
  28. #348
    Dallas, TX
    I agree with crash. Obviously, bead the tubing and use good clamps. That's worked for me so far.
  29. #349
    Indiana
    A few updates. Have an order into VRaptorSpeedworks for some fuel parts, then I'll get the tanks in.
    Had some cooler weather a few days ago so I got some glass on the undersurface of the hood.
    Started the new aluminum paneling.
    Installed the CTS-V alternator.
    Got the clutch line done too.
  30. #350
    Indiana
    I was so close to throwing in the towel on the dual radiators, I wanted completely ducted fans but realized it was going to be a painful time-consuming process to get that done, and I would have had to go with a smaller fan. So I simplified the whole thing by mounting the SPAL fans directly to the radiator (actually to the frame adjacent to the radiators). Should work almost as well as a fully ducted fan.
    Got the cooling system finished. Per my other post, I could not bend the tubing more than about 10-20 degrees without kinking, but was able to make some gentle bends where required.
  31. #351
    San Diego
    Just so you are aware, while those flex lines are easy, they absolutely kill the flow rates. My recommendation to all builders is to avoid those if at all possible.
    www.myraceshop.com
    GTM solution kits
  32. #352
    Indiana
    Got my e-brake and cables done, Wilwood 330-9371 Emergency Brake Cable Kit, Honda e-brake handle. I like how inconspicuous the e-brake handle is now compared to the bulky C5 mechanism.
  33. #353
    Indiana
    Let me know if anyone wants to buy a set of aluminum gas tanks, brand new.
    Got the fuel tanks done. Step 1: buy the crossover gasket kit from vraptorspeedworks.
    I used a 1" wood bit, worked great. Then used a heat gun to soften the edges of the hole slightly so I could thread the AN fitting into the plastic. I would wager that the seal was fuel-tight after this step even before putting the gasket and nut on the back side.
    Then I plastic welded the unused fittings closed.
  34. #354
    Indiana
    Got my seat back from the upholsterer, he replaced the seat foam with a softer foam in the upper layer so my butt is 2" lower.
  35. #355
    Lookin' good!!
    Shane Vacek
    www.vraptorspeedworks.com
  36. #356
    San Diego
    We love watching this project. Wish mine was moving along like yours.
    www.myraceshop.com
    GTM solution kits
  37. #357
    Indiana
    Thanks guys, still a ways to go. I'm looking forward to seeing updates on the GTM-R too, Mike. Finishing up the body mounting, just about have the passenger side done.
    I decided to reverse the door latches, the receivers are on the chassis with the strikers on the doors. My door bars are high enough that my door release pull-straps are at the typical location even though they are on the chassis. So here's my exterior door handle.
  38. #358
    San Diego
    That's cool. I had also thought about putting a handle under there. That looks like a Miata piece?
    www.myraceshop.com
    GTM solution kits
  39. #359
    Indiana
    Yes, Gen 1 Miata. Nice, simple, compact.
  40. #360
    Jul 2014
    Nicely tucked up in there. I have aspiration of putting some type of touch sensor under there so as I walk up to the car with an RFID or key FOB, I can just run my finger over the secrete spot and the door pops open.
