“If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
From the clip of the rules posted it looks like there is no height specified of the door bars. Is that the case? How do you determine how high they must be?
Todd
Todd,
What we were told, is that the preference of the sanctioning bodies was that the bars cover at least 2/3's of the door opening, that in of itself leaves some room for interpretation. The way we worked it out, was to take a measurement of the door opening, not from the sill bar, but from the lower frame rail. From the frame rail to the top of the forward bulkhead is approxmatly 16 1/2", 2/3's of that is 11". We measured several cars that were in the area, and found that most bumpers started at anywhere from 12" to 20", and terminated at 16" to 26" in height(From Hondas to 4x4 Ford Expeditions). With a ground clearance of 4", 4" of distance from the bottom of the 4" tube to the top of the frame rail, and then 11" upwards from there we reached 19" for the top of the upper SIB (Side Intrusion Bar). Any higher, and it starts to become problematic for entry and exit. We moved the top bar outward to negate some of the entry/exit problem, as it ends up providing a little more room to the driver to pivot their body into to the car as they slide in.
Hank
Hank,
Cant wait to see the treatment of the bars with the doors. That should be quite interesting.
Jacob,
Your mods are very interesting as well.
Jim
CP 438, FR 347, TKO 600, Levy/Wilwood 6P/4P
