114
679
I started to connect the E-brake cables below but ran into a snag. I am about 2-1/2" shy of being able to make that connection. I see in the manual where they talk about installing the Wilwood spacer if you are using their brakes. This spacer should give me the length I need, however I don't remember receiving these or inventorying them. I guess worst case I will just cut some pieces at work. They are just slotted brackets with holes on either side (but I will check with FFR first)...
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
