Seasoned Citizen
If you're thinking of bed liner, look at Raptor by U-pol: https://www.u-pol.com/us/en/products...ective-coating
I've used four brands of bed liner and Linex is the gold standard. Raptor is on par with Linex and can be tinted or painted over with your exact color. You can apply it yourself either roller or sprayer. While the product is not cheap it is less expensive to DIY on small parts than taking them to your local Linex dealer.
I should add that it adheres great to fiberglass and I used it on areas of the body that show the rough fiberglass finish to give a finished textured look.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
JOP33 thanked for this post
wrp liked this post
