114
679
So only four hours later I have all the aluminum that I need to take out out (and the trans tunnel and cover of course)...wasn't as bad as I thought it would be...
This is the old Passenger Floor Plate I had made to cover the auxillary fuse block(s) I installed. It was just a little too small for my liking and to protect that area, so I made a second plate that covers much better and has a slight kickout on the bottom (all will be covered with carpet eventually)...
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
