Results 1 to 6 of 6
Thread: Anyone done with template
    I am looking for the template to drill the holes into the aluminum panels. I bought a kit from someone and I cant find that template piece of metal.
    Brian
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Quote Originally Posted by awd-turbo View Post
    Brian
    I used a 1/2" wide by 36" long length of elastic material marked every inch with a sharpie. Secured one end with a cleco, stretched it out and clamped the other end. Then, punched the marks I wanted and they were all evenly spaced.
    Ray
    Vermilion,OH
    The template is simply a strip of aluminum with holes with 2" spacing on one side, for the panel to panel rivets, and the other side is 3" spacing for the panel to chassis rivets. It's thin enough to use a pointed Sharpi, or magic marker, as we used to call them, thru the holes. I haven't measured the hole size, must be 1/8" or 3/16" at most.
    I've made one by using a Stainless Steel Ruler and drilled it with a 1/8" bit on my press.
    It works perfectly, but the stainless was a tad tough so use a high quality bit if you make one using a stainless ruler.
    Heart of Dixie, Alabama
    I will bet FFR will send you one for very little cost.
    Someone is kind enough to send me one.. thanks guys
