Page 7 of 7 FirstFirst ... 567
Results 241 to 263 of 263
Thread: Ducky2009 MK4 Build #9035
  1. #241
    Lilburn, GA
    David - the car looks great! My opinion - no grill, but that's just me. Sorry to hear about the nail in the tire, too.
    Al, I have a friend with a water-jet machine and he is making the grille parts for me. I still have to make the perimeter loop and weld it all together. Was originally going to make it from aluminum, thought I was going to mill the slots where it fits together. He suggested making it from SST and has some extra on hand. He thought it would look better, nice and shinny and it would, but told me I'd have to do the polishing. LOL. Pics to follow, but it will be a while. I'll be in Miami on and off until the middle of Nov. I'm retired but contracted to do some consulting work for an aviation company in Miami, and it happens to be 15 minuted from my 2 year old grandson. Couldn't pass it up.
    Coyote Engine & TKO-600. Solid Axle, 8.8-3.55, Power Steering, Power Brakes, Dual Roll Bars
    Heater and Glove Box, Drop Trunk, Wipers, Radio, FFR Vintage Gauges
  2. #242
    Lilburn, GA
    Carpet around door latches
    I ended up adding plates around the door latches. They're only visible when the door is open. As Paul suggested, I added plates in the wheel well. Also added edging to the carpet, same as Paul. The PS bulb seal is showing more than the DS. I'll try to adjust more.
    Trans re-assembled. Hopefully no more leaks in the future.
    Still need to add seal around the hood and doors.
  3. #243
    Lilburn, GA
    Took a short ride on a cold day (55 degrees). Zero traction.
    https://youtu.be/7oHaXhmEFS0
  4. #244
    Lilburn, GA
    I was out of town for 2 weeks and when I came home, the Roadster would not start.... A dead battery. I charged the battery overnight. The headlights were bright but the car wouldn't start. Thought it was the starter. Tried using jumper cables to the starter after removing it. Solenoid engaged but the gear didn't turn. Was ready to buy a new starter. A mechanic friend suggested I use a different car and try again. Starter worked fine.
    Turns out the battery wasn't putting enough AMPS out. Powermaster starter don't work with a weak battery.
    Moral of the story: I added a trickle charger for when I'm away.
  5. #245
    Thanks For The Suggestions!
    We just got back from a recent trip as well.
  6. #246
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    I have two of these, and fully endorse them Battery Tender Plus
    I use one on my El Camino, and the other on the boat battery (when it's pulled for the season).
    John D. - Minneapolis 'Burbs
    2018 Mk4 Roadster - #9365 Build Thread
  7. #247
    Jan 2018
    I have one of the multi-head battery tenders on my wishlist to maintain the batteries on all the garage toys.
  8. #248
    Lilburn, GA
    OIL FILTER for a 2017 Coyote
    Just started to charge my oil. Problem is, I was told the engine is the same as a Mustang. That new filter is a Ford FL500S, and it hits the frame. It’s approx 3/4” longer than the one that came on the engine. I called Ford Racing, where I purchased the engine, and they are telling me the short one that came on the engine shouldn’t be used at all. Only installed to ship the engine and should be removed and replaced. They suggest using a remote setup, which I have, but didn’t use because it fit as delivered.
    How many people have used the supplied one?
    How many have used the remote filter?
    David aka Ducky 2009
  9. #249
    I have used the short one that fits. On my third one now. First I have heard about this.
  10. #250
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    I am using the Ford one that came with the engine and have 800 miles on it no problems. Will be changing oil at 1000 using a Mobile one M1-113 filter it is the same size as the one that came on the engine. I believe Edwardb posted it in his roadster build. I am not using a remote oil filter myself. I think the smaller on is fine especially with most roadster owners who will take extra care of their cars. I plan to change it at 3000 miles where as a lot of OEMs suggest changing at 7-10k now days. This is from the owners manual for a 2017 Mustang GT 5.0
    When to expect the message prompting you to change your oil
    Interval Vehicle use and example
    7000–10000 mi (12,000–16,000 km) Normal
    Normal commuting with highway driving. No, or moderate, load or towing. Flat to moderately hilly roads. No extended idling.
    5000–7000 mi (8,000–11,999 km) Severe
    Moderate to heavy load or towing. Mountainous or off-road conditions. Extended idling. Extended hot or cold operation. High engine speeds and loads, engine braking and hard cornering.
    3000–5000 mi (4,800–7,999 km) Extreme
    Maximum load or towing. Extreme hot or cold operation.
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
  11. Thanks Ducky2009 thanked for this post
  12. #251
    Lilburn, GA
    Quote Originally Posted by Paul2STL View Post
    ....... Will be changing oil at 1000 using a Mobile one M1-113 filter it is the same size as the one that came on the engine.
    Thanks Paul.... And Paul aka Edwardb,
    I picked up the Mobile One M1-113 and it fits. The FORD FL500S filter was about 3/4" longer and wouldn't fit (hit the frame). Took the factory supplied one to a Ford dealer and they didn't know what it was. The number on it wasn't in the books.
    The pic is showing clearance with the filter installed only a 1/2 turn.
    Scott, not sure what P/N you were referring to when you said the short one.
    FYI... I looked at the remote filter kit supplied with the kit. It doesn't fit the engine filter mount (different size threads).
  13. #252
    The same one you called the short one.
  14. #253
    Lilburn, GA
    Clutch Cable - Broken
    1,000 miles and now have a broken clutch cable. I know others have had this same issue, but can't remember who. Someone listed the Ford P/N but I can't find it. I also remember someone saying Forte has one. I looked it up. The definition says it's NOT adjustable. Not sure how well that fits.
    Please chime in and tell me if you had issues and how the new one is holding up.... and where you purchased it.
  15. #254
    Highly recommend the Ford Performance M-7553-C302 adjustable cable. It's what I installed in my first build Mk3 now almost 10 years ago and still working fine. Many others recommend it as well. Widely available for around $50 and a high quality piece. I personally haven't used the one from Forte, but understand what he's selling isn't the adjustable version.
    Build 2: Mk4 Roadster #7750. Sold 04/10/2017. #7750 Build Thread
    Build 3: Mk4 Roadster 20th Anniversary #8674. 03 of 20. 2015 crate Coyote, 2015 IRS. Legal 04/18/2017. #8674 Build Thread and Video
    Build 4: Gen 3 Type 65 Coupe #59. Gen 3 crate Coyote. Delivered 12/2/2017. #59 Coupe Build Thread
  16. #255
    Lilburn, GA
    Thanks Paul. I found one locally and installed it. I purchased my engine, trans, CLUTCH, etc directly from Ford Racing. I always thought the heavy duty clutch was just harder than normal to push. I'm amazed how easy it is to push now. The new cable has nylon (or similar material) ends.
    Also, the old cable is .120" diameter cable. The new one is .145"
  17. #256
    Lilburn, GA
    Oil Cooler Opening - Screen Covers
    I purchased an oil cooler opening screen from Breeze. First off - It was exactly as described on their web site.
    My issue is the size of the screen mesh compared to the brake vent screens that I received from FF. The FF screens have a smaller mesh opening. I ended up making my own, using steel wire mesh, powder coated (black). (vs Breeze - aluminum). Not exactly the same mesh size, but as close as I could find.
    If anyone would like to purchase the Breeze screen, I'll make you a deal. Cost was $35, plus $9 shipping. Will sell for half price, $22, including shipping.
    If you want a steel on, I'll make you a great deal on one of those too! PM me.
    Edited: The third and fourth pics are the ones I made.
    Oil Cooler Screen - Breeze.jpg Oil Cooler Screen - Breeze - Comparison.jpg Oil Cooler Screen - Home Made.jpg Oil Cooler Screen - Home Made - Comparison.jpg
  18. Likes SerpantFL liked this post
  19. #257
    Senior Member cv2065's Avatar
    Dec 2017
    Quote Originally Posted by Ducky2009 View Post
    I experienced the same thing. Great quality and service from Breeze as usual, the screen size doesn’t align with the FFR ones and I like the finer mesh. Have a picture of the steel ones you made?
    MKIV Roadster - #9380 - Complete Kit - Delivered 7/17/18
    Blueprint 427, TKO 600, IRS
    Build Thread: https://thefactoryfiveforum.com/show...V-Build-Thread
  20. #258
    Lilburn, GA
    The third and fourth pic are the ones I made.
  21. #259
    Dec 2017
    Fl and No More York
    Dave, nice work, I also prefer the ones you made. I think the slightly finer mesh will keep those stones from damaging the cooler...
  22. #260
    Lilburn, GA
    Brake and Oil Cooler Mesh Screen Covers for sale
    Anyone need Brake and Oil Cooler mesh screens? $30 for Brake screens, $25 for Oil Cooler screens, plus shipping. I have a few sets.
  23. #261
    Lilburn, GA
    Bought a new Hot Rod!
    I'm finishing up my MK4 and wanted a new hot rod. Found one. LOL
    I have 11 grandkids. Thought they would enjoy this one.
  24. #262
    Nov 2018
    Beautiful color choice! Keep up the good work!
  25. #263
    Nov 2012
    Cool little hot rod for the kid.
Clever Turn Signal
