For those using the VCP trailing arms, Do you need to bend the frame ears or grind down the spacers on the joint the get them to fit correctly? as is, I would need to bend the frame ear out quite a bit to fit... the stock trailing arms fit without need to bend the ears.
Also seem that I need to put quite a bit of stress on the trailing arms in order to pull it in place to even line it up with the ears on the frame?
