Results 1 to 18 of 18
Thread: Mass AirFlow Sensor for a 2007 C6 LS2 with 58x Reluctor
Threaded View
    Senior Member The Stig's Avatar
    Charlotte, NC
    I am having a hell of a time trying to find the correct Mass Airflow Sensor that is correct for my 2007 C6 Corvette LS2 with the 58x Reluctor (Crate Engine).
    I am using the GMPP LS2 Engine Harness and Computer (E67), that I purchased from Factory Five Racing.
    I started with a sensor that I purchased for the LS2 that didn't connect to the harness connector. I then bought a replacement from Granatelli that I was assured would fit the connector to the wiring harness. It didn't... They said that they must have sent the wrong sonsor, and offered to replace it. I got that one ,and found that it didn't fit either. So I sent it back as well...
    I called Modern Chevrolet in Winston-Salem, NC and talked them through the scenario. They gave me a part number for the Sensor that should fit. I went ahead and bought it, (two weeks ago), and just got it Saturday. As I look at it, I can't see how this is going to work... You can see the plastic "filler" between the MAF connector and the Computer chip housing. Unless the harness connector had a open section on the side to allow it to slip over/around that filler, I don't see it going on.
    I think that I need to be looking for the correct connector to switch out on the harness. Can anyone point me towards the correct part number for that conector?
    The Stig
    GTM #0081
