I will try to make a very long story short ... I have a complete kit with the standard issue brakes, Wilwood 3/4 inch cylinder for the fronts and 5/8 inch for the rear. After bleeding the brakes for two days I am certain there is no air in the lines. The front brakes are firm but the rears are not, I can push the rear cylinder in with my hand. I have adjusted the balance bar from one end to the other. Its like the rear master cylinder isn't holding pressure? I called Wilwood and they said with 3/4 in fronts and 5/8 rear I would never get a firm pressure at the rear, that I should have 7/8 inch master cylinder for the rear. I explained it was an FFR kit and he was very familiar with the deal and assured me I had the wrong size.
So I called FFR and they tell me I have the right size cylinders but that I'll need to bleed both the front and the rear at the same time? I told them what Wilwood said and the response was "we know what works best on these cars"...I wanted them to explain to me why Wilwood said I had the wrong size. Also told them I wasn't too happy with their answer...With no air in the rear line I cannot understand how I can easily push the rear cylinder in by hand, unless the master cylinder is defective?
Any input would be appreciated...right now I am going backwards on this build!
