I purchased both Lizard Skin CI & SC. Also the spraying kit. I applied the sound control today and want to share a very important observation I had while mixing with the drill driven tool. Do NOT under any circumstances accidentally press the trigger on the drill after lifting the mixing tool from the bucket. You will find out how far that dang thing will sling that stuff. All over the floor, wall, garage door, toolbox, body on the body buck, parts boxes, work bench, and if you can believe it, in your hair.
After a substantial clean up I managed to get the 1st coat in. Lesson learned. 😀
