0
Well Used Member
Originally Posted by
srobinsonx2
Boat737 and Roadracer,
Man. You guys have eagle eyes. It was off by exactly one inch. Embarrassing move on my part. I was using a measuring trick i learned from my Dad. He was a carpenter and always made me use the 1 inch mark as my starting point when measurung from a mark (instead of the end of the tape like you would normally do on a hard edge). He said it could be more accurate. Well, that is only true if you don't forget to add an inch on the other end of the tape.
I was so worried about how the stripe was laying out on the scoop i didnt notice it.
Thanks for keeping my straight.
Sorta like the saying, "I've cut it 3 times and it's still too short." Good to work out the mental gymnastics now, and not during the final layout. I know what you mean about using the 1 inch mark as the starting point. I use it with tape measures, but for the really fine stuff, I use a 6" or 12" machinist's scale measuring from the end.
Just curious, are you going to taper the stripes slightly at the front and rear? From what I read, some do, and some don't.
