Thanks Thanks:  61
Likes Likes:  355
Page 9 of 13 FirstFirst ... 7891011 ... LastLast
Results 321 to 360 of 512
Thread: # 1002, SVTFreaks build.
  1. #321
    Sep 2019
    On my gen 2 hood that is exactly what I did. Wait until you go to cut the slot! The fiberglass was so thin there that I could cut it with my knife. After I cut the hole I could pull the aluminum plate out with my fingers it was so weakly attached. I built a plate out of 1/8 steel and then drilled the holes using the hinge as a template then I welded nuts to the plate and slid it back in. After I made the hood alignment I riveted the plate to the hood so it would not move (the hood will still be adjustable) and then glassed the slot. Worked great! Ray
  2. #322
    Prairieville, Louisiana
    Quote Originally Posted by rapidray View Post
    Thanks ray! Glad to read I’m on the right path to something that’ll work!
    Now I just need to get the wife back to work and kids to school to get some good work time lol! Assuming this virus thing don’t make that unsafe that is.
    '33 Hot Rod
    MK4 Roadster
  3. #323
    Not sure if I posted here that I bought the gen 2 hood hinges. Got them assembled and the driver side one hit my air filter. So I cut a wedge extension to move it down and in some.
    Here it is hitting the hinge
    Figured out the angle, cut the wedge out of the same 5” exhaust pipe I made version 1 with, and welded it to v1. Now, I’m no trained welder so after a bit of grinding and putting some body filler on the outside (since it’s gone be painted anyway) to help smooth the surface and seal:
    The surface that it’s sitting on is the end I added the part to.
    ill fill and smooth the rest later. Before paint (I’ll be painting it, the blower, the engine and trans also)
    Now, it is out of the way!
    The kiddos and wife are going back to school soon and time should increase for me. As I’ve said before, I don’t work on it when they are home. As long as corona stays away enough. I got the 13 year old watching the 3 year old for me long enough to try to knock this out. But they got in a tiff before I could even test start it so maybe next week....
    '33 Hot Rod
    MK4 Roadster
  4. Likes FF33rod, shmelty liked this post
  5. #324
    Finally got the hood hinges working right, and the blower intake in the right place out of the way.
    On to redoing thehinge mounts. I don’t like the way ffr says to do it so I am installing a 1/4” plate that will be bonded in. Thisplate will get threadedso the bolts go into there In stead of rivnuts.
    I cut a slot and drilled out the old rivnuts. Then I made 2 plates to go in. I roughed up and cut valleys to help the resin have a place to grab. I tried to stay out of the way of where the bolts would go so the valleys wouldn’t cause a bit to walk. I drilled and tapped the plates so I could use a small bolt to hold them in place with a piece of wood to tighten against.
    Once all parts was ready, I dipped the little bolts in minwax to hopefully allow them to release. If not, I can justgrind them flush. I painted thickened resin on the back side of the hood flat (after roughing up a little with a long bit in my grinder). Painted it up good on the metal plate, inserted through the slot (using a paint paddle to hold it up). Then I used the small bolt and the paddle to pull it up tight. I used a syringe to shoot resin in before pulling it up to ensure it had plenty. Now I’m letting that cure. Next week, I’ll mix some up with some chopped strand and paint it in the back real well to increase strength. Then fill and smooth the slots and the holes used to get it all bonded.
    I also see that my hood has widened a bit at the bottom due to cutting the liner to clear the blower. The front is easy, the gen 2 hinges allow some room to pull them closer together which will pull the front sides in just right. But the back, I will make a plate that will sit perfectly behind the blower in the space before the firewall, and connect the sides using the flats where the pin mounts went on the gen 1 hinge system. That’ll allow me to pull the sides in. I’ll prolly design it out of cardboard and find someone locally to water get it out of 1/16” for me. That should allow me to get the rear to line up just perfectly.
    '33 Hot Rod
    MK4 Roadster
  6. Likes sethmark, TxMike64 liked this post
  7. #325
    I did a whole bunch today but not much to post pics of. I finished filling the slot that i has cut to slide the steel plate in for the hinge mount. After bevelling the edges and laying cloth in (3 layers) and let that cure, I cleaned it up and then layed in some chopped strand to get the thickness back and some more strength. I used that to fill the holes in the top also. After cleaning up and a little skim coat of filler, you’ll never know I did surgery.
    Also today, I extended the mounting tabs for my seat back so it reached the new position of the bottom since I lowered the bottoms. I also cleaned up the glass I used on the inside of the trunk lid but found a weak area so beveled that and filled it back in with resin and chopped strand also. Hopefully, Monday I can clean it and the hood up, throw some filler in and get that cleaned up and start the process of getting them on and right.
    '33 Hot Rod
    MK4 Roadster
  8. #326
    Got the seats modified and lowered. Trimmed the inserts to fit the new position and modified the center hump frame to fit. Still have to build the center insert.
    Then I knocked down the filler and tossed some primer over the patches where I added the plate for the hood hinge. Got a few pinholes. I’ll catch that on final slicking of everything.
    Then I moved on to making the brace to pull the rear edges in. Getting this to line up just right is going to be tricky. It seems the hood wants to bow up on each end also. I’m hoping that pulling them in will get it shaped into place but I’m already considering how to fix that. It may end up requiring some glass ribbing. That’s gonna get tricky with the blower there. Anyway, here is the cardboard pattern then a 1/4” wood pattern that I can bring to the metal shop and have it water jetted out.
    '33 Hot Rod
    MK4 Roadster
  9. Likes JOP33, TxMike64, HVACMAN liked this post
  10. #327
    Today I finished up the Tim Whittaker KVC trunk shocks. It fits great except the bottom is ever so slightly poked out when the shocks are installed. Not sure why, it’s easy to push into place it just doesn’t stay. The latch won’t hold it in place either. So off I go to troubleshoot that. I’m waiting on the good brace from the water jet shop. They (as well as most of south Louisiana) has to take some time off while Laura made her pass through. I’m over near Baton Rouge so it didn’t affect us other than some rain and a good breeze. But those people in west Louisiana and East Texas got it bad. I expected much worse, maybe the rebuild after Rita was up to better code. Only thing I can surmise to why everything isn’t gone like Biloxi after Katrina and that same area after Rita. Anyway, I digress...
    Pics!
    '33 Hot Rod
    MK4 Roadster
  11. #328
    Jul 2017
    San Diego
    Quote Originally Posted by Svtfreak View Post
    Pics!
    Oh man, I'm going to bond in the kit this weekend. Already cut the slots. Thats a bit worrisome about the corners as thats where I'm having the problem myself. Is there a way to just build up the bottom and sand the countour flush?
  12. Likes JOP33 liked this post
  13. #329
    Quote Originally Posted by fostia View Post
    Possibly. I tried to line it up with shocks installed. That didn’t work. Today, I loosened the hinges mounts (the L shaped one that connects the lid to the arm, loosened the two that hold it to the arm) and tapped it forward with a hammer slightly. That helped about 1/2 of the problem. I think, right now, that there is some flex on the lid between the hinge mount and the KVC arms. Def do the arms. It’s easier to deal with this than the mess that I had before with glass that moved day to day!
    Here’s what I think is happening. The are between the hinge pad and the KVC arms is just thin glass. It appears that area is flexing. The trunk profile is staying perfect. Best I can tell, that spot is what’s flexing slightly and letting the bottom come out. If I can’t adjust it out, I’m going to cut out that area, install a new 1/4” thick plate to let the trunk hinge pad bolt to, with a 1/2x1/2 brace going to the end of the KVC arm. I’ll tack that up to remove all flex the glass it all back together to make the whole shebang more solid. But I’m going to monkey with it a bit more before I pull that trigger. I want to try to figure out how to prove that’s what’s happening (ideas anyone?). The big problem is it’s just too large and too flat a glass part. It flexes too much I think.
    Today, I mounted the hood up. I’m still missing the brace for the back to keep everything at the right width. I’ll call that shop later.
    Scribed and predrilled for the mount holes
    Drilled, clearanced the glass and aluminum them tapped the steel plate we put in
    Hood installed. No more rivnuts! Much more solid than it was. Plenty of clearance to the air filter.
    Opens great. Gonna have to put stops so the arms don’t hit the radiator. No prop rod yet. I may try to incorporate a single gas strut on the passenger side (running out of room on driver).
    Pic of the whole car. Back is up cause I’m still monkeying with the trunk. Trying to figure out how to fix the lower corner. They poke out thickness of the glass only when the shocks are installed. Might be flexing the trunk but might be just rotating the skin around a little. Trying to figure best way to fix it, but might have to strengthen the hinge mount area. If so, I’ll be doing the plate mod there also and tacking it into the KVC trunk radius rods.
    Starting to look like a hot rod!
    Side note, I crossed 600 hours into her today.
    '33 Hot Rod
    MK4 Roadster
  14. #330
    Jun 2018
    North Vancouver, BC, Canada
    Couple of suggestions
    - put the weather seal on the trunk before you fully tweak it, it can change how the lid sits relative to the body.
    - put the gas strut(s) on the hood before you mess with a hinge stop, it seems to change how far the hinge rotates (at least on gen 1)
    Cheers, Steve
    Gen 1 '33 Hot Rod #1104
  15. #331
    Cheers, Steve
    Thanks Steve. I will be putting the striping on at some point but I wanna get it closer before I do that. Have to do it and doors that way. These are gen 2 hinges. I am going to try to not put them on fiberglass but on the hinge arms themselves. Haven’t even begun to try to sort that out yet. Either way, anything like that will be done before I do final gaps and fitment. You can see in a pic below, I’ve got a lot of that to do yet. The hood is on, but nowhere near where it has to be. Once I get it’s width fitment and shape right, I’ll tackle that.
    Monkeyed with the trunk lid awhile yesterday. Was able to get it just about right. Need to fit it to the opening now. The latch was a jerk though. The shoulder bolt either hits the body and latch or catches the head on the latch. Actually both. So I cut out the body a little and I put a longer shoulder bolt. Have to get it fit right in the opening now. But didn’t feel like getting glassy today.
    My hood brace was done so I grabbed it and installed it. Fits great. Falls in the perfect spot between the blower and firewall. I did install the prop rod for now. I’ll prolly, even if I get a shock working, leave the call stud and clip on the car even when finished.
    Now, I need help to get the hood curved back down and the sides pulled in. But my dad left for a week and my neighbor (who builds real deal big block racing motors) has diabetes. I don’t wanna chance Giving him the covid just in case I have it at any time since I’m out and about and working. So, the pics below, showing how the hood shape changed a bit when I redid the liner for the blower hump, will have to wait till dad gets back. Yeah, I have some aligning to do, the hood and radiator all need to come back some. The ends will suck in and I’m planning on putting about 3-4 L brackets on the brace up to the hood to hold its shape from side to side. They’ll be adjustable also.
    I did go measure a mile so I could calibrate the speedometer. Almost went to do it, but it’s hot and I’ve got a few things to do before I can drive it.
    '33 Hot Rod
    MK4 Roadster
  16. Likes FF33rod liked this post
  17. #332
    Jun 2018
    I've got the opposite problem with the hood sides at the firewall, they are too tight. However, when I put the pins on I positioned them so they help spread the hood as I push them into the firewall holes. Seems to have turned out ok.
  18. #333
    Yeah the pins do a lot to line that up. But I’ve also swapped to gen 2 hinges which ditch the pins since it doesn’t move forward any longer. It just goes straight up. I thought about pins facing down but elected to try this first. Trying to keep it clean. I do still have to figure out a good latch. Ffr’s method is to rivet it straight to the firewall. I’m not sure I want to go that route yet.
    '33 Hot Rod
    MK4 Roadster
  19. Likes FF33rod liked this post
  20. #334
    Kingwood Texas
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  21. Likes Mrallsport32 liked this post
  22. #335
    Hey Michael. Actually, yes I have. I was originally going to use one on each side, like it appears you are. And it’s not out of the question yet, but I think I want to keep the body slick with few things on it. I could paint them to match and blend in. The two of them I’m not sure about either yet. I know it’s menial, but I’m not sure about the walk around the car to open the hood. I find myself leaning across my cobra to unlatch it lol. But thank you for the link!
    '33 Hot Rod
    MK4 Roadster
  23. #336
    Not a hot rod update today. Don’t feel like going get nasty just to fit the trunk. Waiting on dad to get back to help and door handles for inside. So while I wait....
    I grow muscadines. It’s a southern fruit with a very tough skin in the grape family. Has a divine flavor. This year, I picked 31 lbs from 2 vines and a few of those from wild. That’s 72 1/2 pints of jelly. 27 lbs of sugar. Today, I decided to prepare the juice. I’ll actually make jelly when my mom and dad get back and she’ll come up. It’s kinda become a thing we do every year.
    '33 Hot Rod
    MK4 Roadster
  24. Likes FF33rod, TxMike64, HVACMAN liked this post
  25. #337
    Village Mills, Texas
    My Great Aunt from Alabama used to do the same with scuppernongs (similar). I used to get a bottle of wine and a jar of jelly for Christmas every year.
  26. Thanks Svtfreak thanked for this post
    Likes Svtfreak liked this post
  27. #338
    Quote Originally Posted by HVACMAN View Post
    Ive heard of those but not sure I’ve ever tried them. If it’s similar, I’m sure they are good lol. You can’t beat country cooking and items grown in the wild and then prepared.
    Got parts in! Door handles. guess I’ll mess with them while I keep putting off sanding fiberglass. Lol
    I layed out where I want them and actually screwed them down. Traced the outline for the hole needed.
    Cut the hole. The bracket doesn’t land correctly the way it comes. So I bent it to a steeper angle on each side and cut it to just be held in by tension. Then I decided I wanted the bracket to stay put permanently. So I welded a couple tabs on each end, and glassed that puppy in place. I put a little thickened resin, after prepping the surfaces, and used the handle to hold it in. After it cured, I took the handle out and overlayed glass with resin to add some strength. Also used some flocked resin to fill in corners and add strength. There shouldn’t be a lot of force on the bracket but I’d rather it not fall off if I pull the handle for some reason later on.
    Finished product.
    My second resin application is curing so now I guess I gott find something else to do while the cleaning lady is inside the house.
    '33 Hot Rod
    MK4 Roadster
  28. Likes FF33rod liked this post
  29. #339
    2 updates in one day, wow!
    I’d say that’s pretty dadgum close!
    Let me be perfectly clear and say my problems where not caused by Tim’s trunk lid arms and shocks. They just made it hard to fix due to the stiffness of the lid now. Which I like better. For those who didn’t see, my lower corners where out about the thickness of the glass when everything else lined up
    Here’s what I did and found.
    1) my trunk lid wasn’t fit good enough. It was too tight. I got the gaps closer to right. Sanded a bit off
    2) from where the corners where poking out, I barely loosened the hinge bolts they hold the L bracket to the arm and tapped it forward about the glass thickness.
    3) I redid the gap along the front. It was rubbing after that adjustment.
    4) reinstalled the lid and without the shocks, it was sitting low.
    So far, I did all this with only the bumpers along the top so the height was right there. It started going low to the body several inches above the bottom corners, and then was resting on the glass at the bottom, about 1/2 the glass thickness.
    5) put the shocks on and that pushes the bottom out just perfect that it now lines up. Almost perfectly everywhere but the center of the bottom. That’s still a little high. I’m gonna try to suck it in with the latch. I was able to do this with the latch.
    40 grit on the DA makes a little ouch REAL fast when you not paying attention to where your hand is.
    Now. Gotta get the hood right, the lower cone right. Door panels in. Latches finished, console done, and intercooler system done. Then I think I’m ready to blow it up for paint.
    '33 Hot Rod
    MK4 Roadster
  30. Likes FF33rod liked this post
  31. #340
    Well, I was heading into the shop yesterday to do some door latch work when I noticed my sewer lift station was a bit wet. Stupid pump done got all clogged up I figured. So started gathering stuff to get it out and fix it. Except momma called. Her pool pump tripped a breaker. So headed back there and figured out what all I needed to fix it. New wire, outlet, switch and plugs for it and their sewer aerator. Meanwhile, went back and cleaned mine out. Got cleaned up and threw a load of clothes in the dryer only for it to trip on temp. Started pulling its vent apart and found enough legos in the vent pipe to build a cobra. Mom got home with her parts so I went and fixed all that up for her, she fed me lunch. Back home to finish cleaning the dryer vent and replacing the flex part. By then, it was time to start the chicken parmigiana my wife asked for for dinner. So while I was doing that, the new dishwasher showed up, so then I got the old one out and it back in, finished dinner and at the end of the day, the only thing I did on the 33 was open the trunk looking for my screwdriver.
    Man, sometimes being an adult sucks. Lol!
    Next week the kids are off school a few days and my other day off is my daughters field trip. Week after that, I already know my one day off I have to bring my mustang for ac repair. Hot rod building time is short, even though I was hoping it would increase when they went back to school! Hopefully, I’ll get out there soon. Really would like to have it ready to blow up for paint by January 6th but I have a lot to do considering.
    And, yes, I did wash my hands multiple times and thoroughly after messing with grey water but before cooking!
    '33 Hot Rod
    MK4 Roadster
  32. Likes RoadRacer, FF33rod, j33ptj, TxMike64 liked this post
  33. #341
    Jun 2018
    For what it's worth, when I was talking to the guy that is going to do the final prep and paint on my HR he recommended that I put all the door, trunk, etc seals in place before final fitment. It quite often changes things significantly. Thankfully, the trunk seal is a press on and can be reused. For the adhesive ones, he mentioned it's standard to have 2 sets - one for fitment before paint and the other set for final assembly.... Trunk's looking good!
  34. Likes j33ptj, JOP33 liked this post
  35. #342
    Go
    Several of you more experienced guys have recommended this. I will be doing exactly that. Thanks, Steve.
    '33 Hot Rod
    MK4 Roadster
  36. #343
    Got around to working some today. First thing I did was fix the latch position on the passenger door. It was too far in. I slotted the holes in the door edge and moved the whole latch out. I still have to move the shoulder bolt to match and realign the door. Meanwhile, I made the bracket to mount the pulley for the cable.
    I flipped the cable and out the ball stud on the latch end. This put the adjustment at an easier to get to place. I installed the pulley pretty far back to get a straighter pull off the handle and a pretty straight shot from the arm on the latch. Boom. Works perfectly. Now to do driver side tomorrow and realign the doors. I’m going to fine tune the driver door fit a bit while tinkering with it.
    '33 Hot Rod
    MK4 Roadster
  37. #344
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    That doesn't clash with windows?
    Just curious...
    Robert
  38. #345
    Quote Originally Posted by j33ptj View Post
    Just curious...
    Robert
    Robert, I ditched the windows when I nixed the top. I have the soft top and side curtains now and don’t regret it. However, I don’t think it would have interfered anyway. The windows went to the outside of the frame and all this is even with or inside the frame.
    Got the passenger door lined up and works great! Now to just throw some weatherstripping in and make sure. That should give it just the right force to make the pop a little better. Lemme see if I can link this video.
    '33 Hot Rod
    MK4 Roadster
  39. Thanks j33ptj thanked for this post
    Likes FF33rod, j33ptj liked this post
  40. #346
    Worked on the drivers a bit. I can’t seem to get the latch to catch the shoulder bolt just right. It’s catching the head just a touch and doesn’t open or close smooth due to that. But I space it out one washer (.060”) and it hits the back plate of the latch. I ground .030 off my spacer and it’s still hitting. I think the shoulder bolt may be at a slight angle but I can’t quite get down in there to see. I’ll take out frames and try to make room tomorrow to see what’s going on. Time ran out today. Wife wanted me come help her put up the Christmas tree. Hey, if it makes her happy. That’s my story ans I’m sticking to it. Cause daddy don’t LOVE Christmas. No indeed, I don’t...... lol
    '33 Hot Rod
    MK4 Roadster
  41. Likes RoadRacer liked this post
  42. #347
    I think I am going to make my own door latch rod setup so I can increase the ratio of pull on the latch to the stroke of the handle. And decrease the free play due to cable stretch. This will also get the latch a little farther away from popping open. A safety factor for the suicide doors (on top of planned pin)
    '33 Hot Rod
    MK4 Roadster
  43. #348
    Ba humbug,.... it's only 4th Nov!!! hahahaha
    Thanks for the reply btw!
  44. Likes Svtfreak liked this post
  45. #349
    Jul 2017
    San Diego
    Not sure how pot committed you are to the pulley system but i bought pretty much the same door handles. I used sheathed throttle cables with a cable adjuster near the bearclaw latch (i also bought the pulleys but decided i liked this better).. That way you can adjust the tension very easily. The hardest part is you need to attach a sheath end near the handle (i welded a drilled out nut onto an extension) so the sheath ends always maintain in the same position.... For my exterior handles i bonded this sheath end component to the inside door.
    If this at all interests you, i bought all the components through Venhill USA. I had a hard time finding out where to buy individual throttle cable components and found this to be the best spot. https://www.venhillusa.com/
  46. Likes FF33rod liked this post
  47. #350
    That’s really good idea fostia. My initial response was heck yeah I’ll do that, but I still want to increase the movement at the latch for the amount of pull at the handle. I think the only way will be an uneven lever. Could probably used sheathed cables also but I’ve ordered the rods so I’m gonna give that a shot. Great work though on that!
    '33 Hot Rod
    MK4 Roadster
  48. #351
    Jul 2017
    San Diego
    Also, if you are looking for movement, i used a burr tool to remove material so the handle pulls out further....
  49. #352
    Oh yeah! I can do that. Didn’t think about that. Thanks man!
    Finally got around to using my hood brace to set the hood width. It worked! Yeah, I have to move the grill back a bit and get the gaps right. But now I know it’ll work.
    Next, I’m going to make 2 L brackets per side that will keep the hood top shape in place better.
    '33 Hot Rod
    MK4 Roadster
  50. Likes JOP33, FF33rod liked this post
  51. #353
    Finally got my rod ends and worked on the door latch. The handle end, by using the ball stud, that became the better leverage. So I ended up with 1:1 at the pivot. You can see the different points I tried. It’s stiffer than before but only because now there is no stretch. MUCH safer and not right on the edge of popping now!
    Here is final. I think the angled pivot bar need to be turned around to increase leverage and make it easier to pop. Not sure what I was thinking assembling it that way. Gonna try that tomorrow. But that might actually make me have to remake the rod to the latch. Oh well. Gonna tweak that tomorrow and move to drivers side with still is giving me fits getting it to latch on the shoulder bolt just right.
    '33 Hot Rod
    MK4 Roadster
  52. Likes FF33rod liked this post
  53. #354
    No pics but an update. I turned the angled pivot bar around and it works a lot better. Was able to back off from the latch trio a bit more so the handle comes out some then hits the hard spot after you have some leverage on it. Repeated on driver side and it works awesome. I also finally folded my long, getting old behind up and got in there to see why the driver door wasn’t latching right. It was riding up some and that put the latch moving on the bolt due to the door angle at the front. I was able to adjust the door up a bit at the front and all my door latch problems went away. It took my 6’2” butt longer to fold up and get in under the steering wheel and to unfold after I figured out what was happening than to actually fix it.
    Putting the doors to bed finally. Only have to tweak the gaps and round the edges just a touch, and they are ready for final fill/body work.
    I built my shop about 6 years ago and put 12 4’ florescent bulbs in it. 24x30 shop. It was ok. Over time, they’ve dimmed and some failed. It was about 15k lumens then. Down to about 10k now, prolly a bit less. I ordered 100k lumens worth of led 8’ light strips (10 of them) to replace my old junk. Can’t wait to be able to see in there better! Just in time for the final push on body panel fitment.
    '33 Hot Rod
    MK4 Roadster
  54. Likes RoadRacer, TxMike64 liked this post
  55. #355
    Today, I finished the brackets to keep the hood center in position. Goofball me measured the holes from two different edges so I have to redo them in the cross brace. But they work! The hood curve matches the body and the sides meet up just right. Did a little more gap work so I can get it back mounted to finalize gaps. Maybe tomorrow.
    Also pulled all the plugs checking for an injector leaking down. Didn’t find any fuel puddles. So I turned on the key and system pressured up almost instantly. Only thing I did was add fuel to tank the other day. Maybe my hard start and hard priming was caused by not quite enough fuel in the tank. Gonna try that tomorrow.
    '33 Hot Rod
    MK4 Roadster
  56. Likes RoadRacer, FF33rod liked this post
  57. #356
    Falmouth, MA
    You will love the LED lamps! My garage is 24 x 32 and I have 6, 4' fixtures and it's almost too brite.
  58. #357
    Quote Originally Posted by cob427sc View Post
    Haha yes I do! Mine is 24x30 and I have 10- 8 foots now. I can see! And I’m gonna add 8 more 4’ ones to fill in a few places. Maybe a 9th above my work benches to make that even brighter. I funny thing is, I don’t like bright light. But for body work, I need it super bright. I have them on 2 switches so I can use half.
    '33 Hot Rod
    MK4 Roadster
  59. #358
    Worked on the hood latch. Remade the hood brace to be a bit beefier to double as a latch mount. The shoulder bolt is on here but I forgot to get a photo of that. Will be slotting for it but it landed perfect for now.
    I did mount the latch exactly like ffr said. May have to slit those holes side to side a bit.
    Landed perfectly. The only problem I have is that the latch doesn’t have enough spring to push the hood up when you release it. I need it to pop up to get my fingers under it. I thought about a couple of springs like new cars have but rather keep it cleaner. Can I wind the spring in the latch up more? Anyone do that, or have any ideas?
    ​Aint she sexy....
    '33 Hot Rod
    MK4 Roadster
  60. Likes 33fromSD, JimLev liked this post
  61. #359
    Ok. Well, I been fighting the hood for awhile. Can’t get it to pop up just a touch when released. I have the latch from gen 1 on it, maybe it doesn’t have enough spring? I can’t feel that drastic of a difference between them. Anyway, so I decided to tackled something easier today, after monkeying with about 5 ideas that didn’t work on the hood.
    I finally got a new (real) rivnut tool. So I put the bottom ones in, marked and cut the panel I previously formed. Then did the top. Then I made 3 little brackets to hold it all together in the right place along the middle. Mixed up some resin and two layers of glass. This will hold it when I take it off and build the strength in on the back side with about 5 layers. Then I can shape the front to match the curve and not be a peak. Passenger done! Drivers next week maybe. Running out of time today. I’m hoping life is a little more normal soon and allows some work time. It’s so close to ready for paint. The list is short But a few items are going to take lots of time.
    '33 Hot Rod
    MK4 Roadster
  62. Likes RoadRacer, FF33rod liked this post
  63. #360
    And drivers side done too.
    '33 Hot Rod
    MK4 Roadster
  64. Likes narly1, FF33rod liked this post
