Results 1 to 3 of 3
Thread: Install roll bar
    Senior Member clays123's Avatar
    Install roll bar
    Guys, about to install roll bar. How do I line up the holes in the waterfall? Seems a bit tricky to me.
    Thanks for any help.
    Placitas, NM
    Measure 10 times, cut once.
    May 2018
    Pinckney, MI
    I used the suspended laser pointer method. With the Gen 2 I ended up with a slot, not just a hole. Also, I plan on making a cover so I can remove the waterfall with the hard top in place.
    Also, there will be interference with the fuel system that you need to resolve. That’s on my to do list.
    - Peterh226 #1134
