Thanks Thanks:  2
Likes Likes:  27
Page 7 of 7 FirstFirst ... 567
Results 241 to 256 of 256
Thread: Fidget Build - Tim - Frisco Texas
  1. #241
    Nederland, Texas
    Tim, did you get a tracking number. I received an email on 12/6 that said mine shipped that day and I would receive a tracking number. Nothing yet.
    33 Hot Rod Stage 1 delivered on 4/27/2017, Stage 2 delivered on 9/21/2018
    LS3 376/480, 4L70E, Electric PS, Classic Auto Air, Lokar electronic sport shifter,
    Ford 8.8 w 3.73 w 4 link, Billet Specialty Legend Series MAG wheels and Mickey Thompson
    Sportsman S/R 26x8x18 front and 29x18x20 rear tires
  2. #242
    Nederland, Texas
    Quote Originally Posted by HVACMAN View Post
    Never mind.... It was waiting for me when I got home from work.
  3. #243
    Senior Member TDSapp's Avatar
    Frisco, TX
    The tracking number was there or the parts were there?
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  4. #244
    Nederland, Texas
    Quote Originally Posted by TDSapp View Post
    The parts. Thanks Tim.
  5. Likes wrp liked this post
  6. #245
    Frisco, TX
    I have still been working on the Hot Rod but have not updated the thread recently. It seems that I get a few steps forward and then have to take even more steps back.
    The brackets and pulleys I bought for putting the accessories on the front of the engine are just not working out. They either don't line up or I can't find the correct part. So I started looking into the accessory package for the 350 SBC. When measuring I found that I was going to have to move the engine back a half inch so the pulleys can clear the steering rack. So last week I ended up pulling the engine and transmission once again. I had actually not though about how far along I was. It took quite a while to disconnect everything and get it ready to be pulled.
    This at least gave me an easier time in drilling and riveting in the firewall and foot box panels. I will also put the steering linkage and everything back together before the engine goes back in.
    Since I had the exhaust disconnected from the headers I pulled it as well. This way it will be easier to wrap the exhaust pipes and mufflers. I got the muffler and pipe wraps for Christmas so I was going to have to pull it anyway.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  7. Likes wrp liked this post
  8. #246
    Nederland, Texas
    You might check CVF Racing. That's where I got mine. They were very reasonable and excellent quality.
  9. #247
    Frisco, TX
    Happy Happy Joy Joy! FedEx made a delivery today.
    I added the coke can to give some scale.
    I was not sure what was going to show through once mounted but I am happy with how it looks.
    I am happy with the fat and skinny look with the size difference.
    Now I have a new problem! One that I have never had before. The lug nuts fits down in a "tunnel". They are so narrow that I can't get a socket down onto the lug nuts to tighten them. I could probably buy a thin wall socket to get them in, but I would be worried about getting them tourqued. Any one have any ideas?
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  10. Likes wrp, HVACMAN liked this post
  11. #248
    Aug 2013
    Gatineau, Quebec, canada
    Now I have a new problem! One that I have never had before. The lug nuts fits down in a "tunnel". They are so narrow that I can't get a socket down onto the lug nuts to tighten them. I could probably buy a thin wall socket to get them in, but I would be worried about getting them torqued. Any one have any ideas?
    I used a splined nut on my wheels, did two things, looks good, easy to install and hard to steal wheels! Well, that's three, your local wheel place should have them.
    20181129_200029.jpg 20180504_140900.jpg my tire wheel supplier also gave me the socket that goes with it when I got the nuts.
    Also, you should look into hidden valve stems!
    20180407_132403.jpg this is with the valve stem on
    20180504_140855.jpg valve stem remove and cover on (look at the bottom portion of the rim)
  12. Likes HVACMAN liked this post
  13. #249
    Frisco, TX
    Thanks for that info. I will look into them.
    As for the valve stem... AR puts them on the back of the wheel. Just about can't see them at all.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  14. #250
    Kingsland, TX
    Thin wall lug nut sockets
    See Amazon
    I believe HF has a nice set too.
    -- Mike --
    TxMike64
    TxM Garage
  15. #251
    Frisco, TX
    See Amazon
    Thanks for that link. From that page I was able to find a singe socket that fits and ordered it. Sadly since it will only be used on the Hot Rod I have to add it to the budget. At least it was only $11.50.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  16. Likes wrp liked this post
  17. #252
    I call BS. I have to buy a new socket every time I need to do something
  18. Likes TxMike64 liked this post
  19. #253
    Nederland, Texas
    Congratulations Tim they look awesome!! Mine came with a thin wall socket. I checked and it fits down in the "tunnel" just like it is supposed to. So you should be ok to torque with it.
  20. Likes JimLev liked this post
  21. #254
    Senior Member JOP33's Avatar
    Haslet, Texas
    Wow...those are some WAW! They are going to look great!
    33' Hot Rod Coupe/Roadster, Fenderless (Maybe), Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18
  22. #255
    Frisco, TX
    Went to Discount Tire over the weekend to have the tires mounted and balanced. The manager really did not want to do them for fear that something would happen to the wheels and he would have to replace them. But in the end he charged me more and I got them done. Cost me $250.00 to get them done but they were good and quick.
    Funniest part was they were apparently the biggest tires that anyone had brought in. At one time out of the eight or so guys working there, six of them were working on my wheels.
    One group of guys were working together to try and get them on the machine. Turns out the machine they had it on was too small and they had to move them to a bigger one.
    In the end though they got them mounted.
    Everything came out balanced as well.
    All of this was also supervised by by best helper...
    She would not stop watching what they were doing. When the first guy came and took the wheel she started telling on him. "Grandpa, they are taking your wheels..."
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  23. Likes TxMike64, HVACMAN liked this post
  24. #256
    Oct 2014
    Vermilion, OH
    Those look great and the helper is a cutie.
    CVOBill
    MK4 Picking up 1/19/19 306 Blueprint, T-5, 4-Link, 17" Wheels, Gas-N Pipes, Heater
Lodestone Billetworks
