Out of Sight Audio
Thanks Thanks:  8
Likes Likes:  30
Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 157
Thread: #998 Build Page
    Placitas, NM
    It might fit better if you didn't use the bracket and mounted the fuse panel on stand-offs to the pedal box.
    Nederland, Texas
    Thanks Jim. The wife has been in the hospital since Saturday, so I haven't spent any time on the build. I will look onto that. I have taken the fuse panel out of the box but nothing else. Hopefully this weekend I can spend some time in the shop.
    33 Hot Rod Stage 1 delivered on 4/27/2017, Stage 2 delivered on 9/21/2018
    LS3 376/480, 4L70E, Electric PS, Classic Auto Air, Lokar electronic sport shifter,
    Ford 8.8 w 3.73 w 4 link, Billet Specialty Legend Series MAG wheels and Mickey Thompson
    Sportsman S/R 26x8x18 front and 29x18x20 rear tires
    Placitas, NM
    Sorry to hear about your wife, hope it's nothing too serious.
    Nederland, Texas
    Thanks Jim. They're not sure we are headed back to the cardiologist this afternoon.
    Placitas, NM
    Andy, I sort of decided to follow your suggestion about the fuse panel. I didn't like the way it hung down on the flimsy aluminum bracket.
    I took it off and mounted it directly to the pedal box frame. Had to fab one bracket to mount the front part to the frame.
    Nederland, Texas
    I hope to work on that this weekend but I think I will mount it on the left side of the pedal box and place the ECM and engine fuse panel to the right of the pedal box. Between it and the a/c unit. I have decided to mount the TCM on the driveshaft tunnel under the console.
  7. #87
    Nederland, Texas
    I went to the Spindletop Car Show and Cruise last weekend. IMG_1105.JPGIMG_1103.JPGIMG_1100.JPGIMG_1111.JPG The grandson got to sit in his first $250,000 supercar.IMG_1116.JPG and the wife and I made the cruise in the Super Bee.IMG_1124.JPG
  8. #88
    Nederland, Texas
    This week I mounted the main harness fuse blockIMG_1131.JPG on the left side of the pedal box and the ECM got a new home on the right side of the pedal box. IMG_1130.JPG The engine fuse box will mount below the ECM.
  9. #89
    Nederland, Texas
    We had company all weekend so garage time was limited. However I managed to finalize the ECM mounting IMG_1134.JPGand fabricated a hinged plate along the lower angled portion of the pedal box. This is where I mounted the engine fuse box. IMG_1137.JPG I hope to place the harness connectors etc, in there.IMG_1135.JPG
  10. #90
    Nederland, Texas
    If any of this looks wrong, or may cause problem down the road, please let me know.
  11. #91
    Nederland, Texas
    Now I know why I have been dragging my feet on the wiring. It can be overwhelming when you look at the big picture. IMG_1081.JPGIMG_1141.JPG I just have to remember "how you eat an elephant....... one bite at a time". lol I did get the alternator wired up. I stripped the alt/accy. wire out of the harness and moved it to the radio/wiper/heater section, so I can use it as an extra accessory circuit. I'll just need to add a fuse. I also stripped the fuel pump wire from the rear harness and replaced it with 10 ga. wire from the engine fuse panel. I will let the engine computer control the pump. I am running the Boyd tank with a Stealth fuel pump. Is there any reason why I can't ground the fuel pump to the chassis near the tank. I need to figure out how to incorporate the inertia switch in to the circuit. I am using the LS3 376/480 with a 4L70E trans.
  12. #92
    Nederland, Texas
    I was on vacation last week but my garage time was limited. Spring time seems to bring a lot of honey-do's with it. However I was able to sort out some of the wiring. The front harness is in place and the horns are terminated. IMG_1149.JPG The rear harness is in place, the fuel pump, and sending unit are terminated. I have the O2 sensors installed and the wire routing finalized. IMG_1144.JPG IMG_1143.JPGand this mess IMG_1146.JPG turned into this smaller mess. IMG_1148.JPG. Slowly but surely.
  13. Likes wrp liked this post
  14. #93
    Nederland, Texas
    Well...... I haven't posted to this thread in a while. Moving, rearranging, removing, and reinstalling components and wiring. I think I have most everything where I want it now. It has been very frustrating. I managed to get the interior bulkhead panels installed along with the accelerator pedal installed. The heater hoses (inside and out) are mocked up. I also plumbed the fuel vapor canister to the purge valve and ran the wiring to the interior of the car. I am hoping I don't get any radiant heat from the engine compartment through the firewall. The firewall has two coats of Lizard Skin and two layers of Dynamat. Then the interior Bulkhead panel has a coat of Lizard Skin and a layer of Dynamat with an air gap between it and the firewall. I have the wiring for the a/c and heat mocked up and now I am hoping everything fits behind the dash when I receive stage two. IMG_1183.JPGIMG_1183.JPGIMG_1205.JPGIMG_1206.JPGIMG_1207.JPGIMG_1209.JPGIMG_1210.JPG
  15. Likes wrp liked this post
  16. #94
    May 2016
    North of sacramento Ca.
    That is the tough thing about not having all the parts and body to put on first.
  17. #95
    Nederland, Texas
    That's true. So far everything is well forward of the master cylinders. I have my fingers crossed.
  18. #96
    Nederland, Texas
    I did yard work on Friday and I had chores to do all day Saturday but yesterday I got the accelerator pedal modified and mounted. IMG_1212.JPG
  19. #97
    Nederland, Texas
    Stage 2 is finally on order with an 8/25 production date.
  20. #98
    Placitas, NM
    The spare clutch pedal for the gas pedal. I haven't mounted mine yet, hope to have that done this week.
  21. Likes HVACMAN liked this post
  22. #99
    Parts coming in
    I have had a problem with the FF down pipe hitting the frame on the right side. Attachment 80065I worked all day Saturday loosening motor mounts shifting things around etc. I finally got the laser out to check the drive train alignment. Attachment 80067 At the end of the day this was the best I could do. I hope it is enough.Attachment 80066 Someone suggested prying between the frame and down pipe, but I was afraid of shattering a brand new set of Hooker manifolds. Cast iron and stainless are both pretty brittle. On a better note the accessory drive and A/C came in on Friday. Attachment 80068 That will give me plenty to work on in the upcoming weeks and I can start the wiring.
    All,
    I’ve decided to eventually start a 33 build but I keep reading here in this thread and others, that “this ____ (fill-in the blank) “came in today” or “the _____ wasn’t shipped and is coming”. I’m concerned about this as I will be a mostly after work/weekend builder that can’t be around during the day to receive all of the missing or late in arriving kit pieces. Should I be concerned and need to figure out an alternate shipping address (work) for these late arriving parts?
    Any feedback you all could provide would be appreciated.
    Mario
  23. #100
    Senior Member JOP33's Avatar
    Haslet, Texas
    Mario - I received my kit back in April of 2017 and initially I had a few bolts missing, a damaged radiator hose and my wiring harness was on back order. After doing a thorough inventory (this is key), I called FFR and in two days the missing parts from inventory arrived and within two weeks of my kit delivery my wiring harness was at my door. Since then I have only had to call them (about parts) once for the 12 point bolts for the driveshaft and they had those delivered the next day (on Saturday). As far as my experience goes, I have been extremely happy with FFR's support. I do understand your concerns though. My brakes were drop shift directly from Wilwood and just left in (2) boxes in front of my garage with the Wilwood logo printed all over the boxes. I am sure there are a hundred or more negative experiences out there, just wanted you to know that sometimes they get it right too. If I might add one tip, plan your build out. There will be items that you want to upgrade from a third party supplier or maybe it is something that didn't come with the kit. Try to stay about three weeks ahead of what you are currently working on so you can order what you need and have it ready when you need...but most of all enjoy the ride!
    J
    33' Hot Rod Coupe/Roadster, Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19
  24. #101
    J,
    Thanks for the advice on the planning out the build, I’m big into that being in construction. I want to approach the build like a construction project without the schedule. Did you attend the build school and if so how was it and is it worth it, I haven’t built anything with a motor since high school and those were VW bugs that I helped build? I’m hoping my being an electrician, general handy guy around the and the support of the FFR community that I’ve got what it takes to finish a build.
    Thanks for sharing your experiances.
    Mario
  25. #102
    Member Tampa33Build's Avatar
    Feb 2017
    Lutz, Florida
    Mario,
    I have to say FFR has been great in answering any questions and sending missing items. I went through the inventory twice and still came up short a couple items so far in the build. Each time I contacted them they shipped the item out the same/next day. I also went to the build school, the main reason was to reinforce I wanted to tackle the project. Some of the items at the school were dated, FFR was in the process of updating them. For me it was worth it. Additionally, the people on this forum are great, I contacted several in my area and visited their builds.
    Neil
  26. Likes wrp liked this post
  27. #103
    Haslet, Texas
    Quote Originally Posted by Cali-21 View Post
    J,
    Mario
    Mario - I did attend the build school and was very pleased with the experience I received. I think the only thing differently I would have done would have been to receive my kit and have it for about a month or two before going. I went about a month prior to receiving it and feel like I would have had some additional questions to ask if I had waited. Remember you are trying to build an entire car in 3 days, so there are some instances where sub assemblies have been left together from a previous class (i.e. you are probably not going to build the entire brake assembly, but you will install the brake assembly). They do a really good job of advising you when and where to stray from the manual and when it is all said and done you meet a great group of people and create a nice network for support.
  28. Likes wrp liked this post
  29. #104
    J,
    Thanks again, great advice and when I pull the trigger I hope to hear from you on future posts.
    Andy, things are looking great to me, looking forward to following your build and will take any advice I can get when I start mine.
    Mario
  30. #105
    Hi Andy...I see you have LS3 and auto trans...I am looking for the thread that talks about the cold air intake and for that filter. I have seen it but of course can't find it now. Can you or some one else help me find it again?
  31. #106
    Nederland, Texas
    Quote Originally Posted by 60's Kid View Post
    I haven't gotten that far but if you will look at JimLev's build he did an excellent job on his and I believe even lists part numbers.
  32. Likes wrp liked this post
  33. #107
    Nederland, Texas
    It felt good to get back in the shop Monday after a long absence. Life tends to get in the way sometimes. I managed to get the oil pan on the LS3 replaced. Not only is it above the frame rails now but I have tons of room to re-clock the PS motor and get it above the frame also. Maybe I'm just paranoid, but it made me nervous with them hanging down unprotected. These cars are low enough without things unnecessarily sticking out the bottom. IMG_1227.JPGIMG_1228.JPGIMG_1229.JPGIMG_1230.JPGIMG_1231.JPG It was a lot cooler in the shop too. IMG_1232.JPG
  34. Likes wrp, JimLev liked this post
  35. #108
    Nederland, Texas
    Saturday I clocked the PS motor and got it nestled up inside the frame rails. Then I assembled all of the steering system. The only modification I had to make was to cut 1/4 inch from one of the DD shafts.
  36. Likes wrp liked this post
  37. #109
    Nederland, Texas
    Stage 2 is here!!!! I plan to get the inventory done tonight and boxes stored. I'm looking forward to getting the trans. tunnel set in the car so that I can do some final routing of the wiring, and locate the final resting place for the shifter. As a side note, I felt sorry for Warren, the Stewart driver. IH10 to Houston was shut down yesterday due to two fatal accidents three or four miles apart. He would have to take a two lane. His next stop was Jersey Village, then Pflugerville.
  38. Likes AJT '33 liked this post
  39. #110
    Placitas, NM
    Ah, Christmas in Sept.
    Have fun unpacking and doing inventory.
    I don't remember, are you using the same Lokar shifter that I bought?
  40. #111
    Nederland, Texas
    Yes. It's been sitting on the shelf, quietly waiting, for about six or seven months.
  41. #112
    Nederland, Texas
    It's been a while since I updated this thread. My wife, who already had health issues, suffered massive blood clots in September. After 28 days in the hospital and a miracle procedure, we are home, but recovery will be long. I have been able to spend a few hours in the shop this week. I installed the rear exhaust only to find the driver side intermediate exhaust pipe was contacting the bottom frame rail where it passes through the frame.Attachment 98024 I had to cut a notch at the flange pull it up and have it tig welded. After getting all the parts mocked up I realized the drivers side was approximately 3 /4 inch shorter than the passenger side. This caused the tailpipe to contact the upper control arm mount. I had a local guy cut two 3/8 stainless spacers to go between the shorty pipe and the intermediate exhaust pipe.IMG_1303.jpgIMG_1306.JPGIMG_1290.JPGIMG_1291.JPG
  42. #113
    Placitas, NM
    Hope your wife is feeling better.
    I noticed your muffler pic has the seam on the top. IIRC I thought I read somewhere the seam goes on the bottom, don't know if it really matters or not. Just thought I'd mention it.
    I just finished insulating my mufflers, even with insulation on the floors the floors were too hot to touch for more than 5 sec.
    '33 Hotrod, #1047, delivered on 2/27/18, go cart on 9/24/18.
    LS3 w/4L65e, Lokar shifter, Electric PS, Vintage AC/Heat/Def, 8.8" 3.55
    TorqThrust II Wheels w/Toyo Proxy T1 Sport Tires, F 245/45ZR17 R 295/35ZR18
  43. Thanks HVACMAN thanked for this post
  44. #114
    Nederland, Texas
    Thanks for noticing Jim. I don't know why it would make a difference on a muffler but I will do some research. I just read your post on the muffler insulation. I'll be watching for your report on the results.
  45. #115
    Nederland, Texas
    I pulled the trigger on a set of wheels this weekend. This is something that has been on my mind for some time. Billet Specialties ran a 15% off special for the holiday and it was to tempting to resist. I went with the Legend Series "Mag".
  46. #116
    Andy
    Mufflers are always designed to channel and control condensation so IF the manufacturer says this side up it will last longer
    that way.
    Dale
  47. Thanks HVACMAN thanked for this post
  48. #117
    Nederland, Texas
    Quote Originally Posted by myjones View Post
    Andy
    that way.
    Dale
    Makes sense Dale. I remember the older mufflers had a condensate drain hole on the back end. I will swap them.
  49. #118
    Placitas, NM
    Nice wheels Andy, what size did you get?
  50. #119
    Nederland, Texas
    Thanks Jim.
    18x7 Front and 20x15 Rear I had been looking for quite awhile. It was between them and the American Racing Torque Thrust. The sale was too good to pass up.
    I hope I have my backspacing close. 4.5 front and 4.0 rear. I will not be running fenders.
  51. #120
    Senior Member TDSapp's Avatar
    Frisco, TX
    Thanks Jim.
    Andy,
    If you don't mind me asking, what did you pay for the wheels? I was just on their site this morning and they don't have any prices listed with their wheels.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  52. Likes HVACMAN liked this post
