Brake Bleeding
So I have this reoccurring nightmare that when I go to bleed the brakes that brake fluid will spew out of every fitting within the line plumbing! I then wake up in a cold sweat only to be faced with an infinite number of shock assemblies that I have to place the spacers and bolts on! With that being said, do any of ya'll have advice on protecting the paint and other items of interest during the brake bleeding process as I have been warned that brake fluid will remove craters off the moon?
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
