0
0
Front / Rear weight balance
This section is pretty quiet. Hope nobody minds a few questions on car builds and set-up. If this post shouldn't be here, please advise.
How important is front / rear balance? I have seen corner balance results at 48/52 or maybe 46/54. Is there a preferred ratio? What happens to handling as it changes? With performance daily drivers it is all over the map, they all seem to work, albeit some better than others.
If it matters I'm planning on 275 and 315 or 335 Hoosiers for the track. Will be driven on the street with appropriate tires.
I know that this question is in the hypothetical range and general information will be appreciated. My build is just starting and completion a long way off.
Happy 4th. A great day indeed!
Jim
- You may not post replies
- You may not edit your posts
Forum Rules
