Results 1 to 5 of 5
Thread: Door Sill Trimming - Riddle Me This
    Sep 2015
    Beachside
    I suspect that my 289 body may not get trimmed the same way as the MkIV (actually, I'm fairly certain of this based on the lower valence issue I and others have had).
    Today's question relates to the door openings. I have a flange on my door openings that does not appear in the instruction manual. If I look at the manual, it appears that the door aluminum butts up against the body, and the fiberglass edge is finished off with a piece of the C trim.
    Here is what I have:
    The body comes up, then takes a 90 degree turn into the cockpit. This causes interference with the door hinges, door aluminum, etc.
    I believe that I need to cut back the area that is hatched in the picture. If so, how far up do I take it on the front:
    And how far up on the back?
    If anyone can share some similar photos of their door openings, it would be helpful.
    FFR #8833 289 FIA 3-link
    Pretty sure that's how its supposed to be. I do trim it so that its about 1/2 wide so the trim fits over it.
    On the Mk4 roadsters I clean them up to make the flange width consistent and smooth the raduis but do not eliminate it altogether.
    EDIT: found an in process photo that kind of shows the flange---
    Sep 2015
    Beachside
    Very helpful, thanks guys!
    Yep. I like the 1/2 inch.
