Just a friendly update... thanks to a fellow forum member who helped me identify a couple of minor deficiencies in my design... a minor rework is underway.
Should actually result in far simpler brackets (all straight, no angles) and mounting points, as well as a more reliable and efficient pull.
I also realized that the handle is so close to my shifter, that easily installing my shifter boot will be an issue, so the whole thing is going to be moved forward almost 2 inches.
*edit: thread pics above updated with fix*
