Thanks Thanks:  6
Likes Likes:  97
Page 1 of 4 123 ... LastLast
Results 1 to 40 of 128
Thread: Tampa33Build
    Senior Member Tampa33Build's Avatar
    Feb 2017
    Lutz, Florida
    Tampa33Build
    Been slacking on starting my build thread, thought I would get it up to date
    23 July 2017
    #1013 Rainy delivery day
    Inventory completed. IRS center section and spindles, gauge clusters, sound insulation kit, and front suspension parts back ordered
    18 August 2017
    Frame back from powder coating
    27 August 2017
    Floor panels, fire wall, driveshaft tunnel, lower waterfall drilled.
    Glove box cutout and fitted.
    Wanted to thank kraftee again for finding the mold and having the glove box made for me.
    Frame looks amazing!
    Feb 2017
    Lutz, Florida
    Pro Coat Performance Coating of Tampa did a great job. The day I dropped it off their compressor went down and it took an extra week to complete it, but the wait was worth it.
    Senior Member kraftee's Avatar
    May 2013
    Gainesville, Florida
    The red frame looks way cool! And you're most welcome for the glovebox. When you get closer to that point, glad to send pics of how I installed mine. Looking forward to following your build!
    ERIC
    "If everything seems to be coming your way, you're probably in the wrong lane."
    Feb 2017
    Lutz, Florida
    It has been sometime since I had a chance to work on the 33. Grandkids, Daughters, and work always seem to have precedence.
    I finished installing the IRS and it does not appear correctly mounted to the front IRS mounts. I installed the 31/16" sleeves in the front IRS mounting polyurethane bushings per the manual page 82. These sleeves appear to be too long. With the bolts torqued to 100ft lbs the sleeves cause a gap between the IRS mounts and the bushing. Shouldn’t the IRS mounts be tight against the polyurethane bushings or is this normal? To have them tight against the bushings would require shorter sleeves, this might add additional stress on the IRS mounting brackets.
    Feb 2017
    Lutz, Florida
    Received the correct RS bushings from FFR. Have to say they have been great at sending items that were missing or incorrect. Completed the break lines as much as I can while waiting on the Whitby power brake kit. Used one of the 20 inch FFR lines to get the correct bends as a model and then transferred to a brake line to be installed. Straightened the 20 inch section back out and repeated for the next section.
    brake line rear_2_a.jpg Brake line front_a.jpg brake line rear_2_a.jpg Brake Line Front_1a.jpg E_Brake_e.jpg Brake line rear_a.jpg
    Gatineau, Quebec, canada
    And i thought i was going to town in getting my stuff painted!! Looks amazing!
    Onalaska, TX
    AJT,
    What type of fasteners are you using to hold the brake tubing to frame?
    Thanks, Bob
    Feb 2017
    Lutz, Florida
    Procoat of Tampa did an amazing job on the frame. I purchased a powder coat system and did the smaller parts that fit in a toaster oven. Made a makeshift coating box out of PVC pipe and cardboard. Still learning, but not as hard as I thought.
    Feb 2017
    Lutz, Florida
    Dodgeman,
    I used the FFR fasteners supplied with the build.
    Neil
    Quote Originally Posted by Dodgeman View Post
    AJT,
    Thanks, Bob
    I will be using the fasteners from FFR as well.
    Andreas
    Dec 2014
    You're in Lutz? I'm in Northdale. I'd love to see your build.
    Feb 2017
    Lutz, Florida
    Mick
    No problem, just finished fitting the doors. Trunk an Hood are next.
    Neil
    Feb 2017
    Lutz, Florida
    Completed the body, door, hood and trunk fitment.
    Removed the body this week and installed Whitby's power brake kit
    Feb 2017
    Lutz, Florida
    Engine and transmission installed today
    One setback today the Sanderson headers CC17-SEC I installed will not work. The right side is too close to the firewall. Sanderson is going to mount a CC16 to an engine Monday to see if the dimensions I gave them will work with my Blueprint SBC 400 Vortec engine. The manual states to use Summit Racing SUM-G9005 or Flowtech 11102 however they are not available in ceramic.
    Hindsight would have been to install the headers after installing the engine.
    looks great! fyi, the first two engine images don't seem to be working..
    Dec 2014
    So what tranny did you go with? We are trying to decide between the AOD, AODE and the 4R70W. AN older thread I read said the 4R70W did not fit and our car is an early kit. Something about the electronics pack. Not sure if there is a dimensional difference between the AODE and the 4R70W. Whichever we get must handle 600 hp.
    Dec 2014
    Oops never mind. You are using a GM motor.
    Feb 2017
    Lutz, Florida
    Went with a 700R4, did not want a standard.
    Red really pops, looking great
    Senior Member TDSapp's Avatar
    Frisco, TX
    Quote Originally Posted by Tampa33Build View Post
    May not have mattered any way. If you read their fine print they will not warranty the powder coated headers when using them to break in a new motor. Yours looks new so it might get the PC too hot during the first run and when getting the timing set.
    I bought the Summit painted headers for $119 to use during my break in and am just planning on getting them powder coated at a later time.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Kingsland, TX
    Nice! That's the same setup and install method I'm considering: Whitby Power Brake kit and use braided lines from the MC down to the hard lines.
    Feb 2017
    Lutz, Florida
    Added spacer to the motor mounts to move the Blueprint 400 SBC back 1/2" to clear the steering rack. motor clearance.JPG Engine Mount.JPG
    I did not like the FFR provided round spacers for the 700R4 transmission mount, so I milled out a new mount from an aluminum bar to raise the transmission the same spacing with mounting bolts to the transmission mount and transmission bracket.
    FFR shipped the wrong driveshaft with the kit, contacted Dan and had the correct driveshaft for the IRS in two days. Great service!
  24. Likes Mrallsport32 liked this post
  25. #24
    Looking Good!
  26. #25
    Feb 2017
    Lutz, Florida
    Had to take a few weekends off from the 33 and paint the outside of the house before the HOA issued a violation. It has been 12 years since the house was built and it needed it.
    Exhaust installed for the second time. I moved it from the between the V frame and the shock to inside the IRS V frame.
  27. Likes Mrallsport32 liked this post
  28. #26
    Mar 2018
    Yucaipa, CA
    Nice job, very nice. My 33' kit is on order but I have a 1000 questions running around in my head and your pic's offer some answers. I also have SBC going in and same general configuration as you. I want to run a Taller air cleaner like yours ( not the little skinny 2" ) and am concerned about hood clearance. Looks like there will be. THEN FF5 tells me I will have to run a short water pump for steer clearance but you seem to have enough room even with a ribbed belt. Then,,, I have the same Mental header issue you are having. I really don't want a painted version that will look like crap down the road.. I still have time to ponder all this. Thx from Yucaipa CA.
  29. #27
    Feb 2017
    Lutz, Florida
    Vintage AC and hoses installed
  30. #28
    Placitas, NM
    Nice job Tamps33. I'm getting ready to install the AC and heater lines. Is there enough room between the frame and body to run the 4 lines outside of the frame?
    Are you going to insulate the exhaust pipes before and after the muffler?
  31. #29
    Feb 2017
    Lutz, Florida
    OnlyAndy,
    Thanks, I had to move the Blueprint 400 SBC back 1/2" to clear the electric steering. I tried Sanderson headers after sending them the measurements. They were extremely helpful however the passengers side did not fit. They recommended changing it out however I decided to go with Summit headers and sent them to Jet Hot for coating. The people on this forum are great, review all the builds you can while you are waiting on delivery.
    Neil
  32. Likes Indigo808, wrp liked this post
  33. #30
    Feb 2017
    Lutz, Florida
    JimLev,
    I took the chance that there is enough clearance for the 4 lines. If not I may have a re-do, been there before. I did not plan on insulating the exhaust. May add with a second layer of Dynamat and Dynaliner with the FFR heat/sound shield.
    Neil
  34. Likes wrp liked this post
  35. #31
    Jan 2016
    Nice looking SBC build. Good to have some other builders close. I sent you a PM with my contact info. I am building a SBC 383. Good to know about the headers
  36. #32
    May 2018
    Pinckney, MI
    I'm looking at the Blueprint 383 with EFI. Wondering about headers as well. Also, what are you doing for the fuel pump? FFR EFI option or something based on the Botd tank?
  37. #33
    Feb 2017
    Lutz, Florida
    I currently have the FFR tank with the in tank EFI pump. I have been looking at the Boyd and new FFR tank, just have not convinced myself it is worth the extra money. Also as pointed out by Indigo88 an in tank fuel pump requires removing the body to replace it. The Blueprint engine comes with a holly sniper EFI and an external fuel pump, so I already have an external EFI fuel pump. I'm very happy with the Summit headers coated by Jethot.
  38. Likes wrp liked this post
  39. #34
    Feb 2017
    Lutz, Florida
    Wiring has taken longer than I planned. Gauges installed for go-carting. Waiting on wheel and tire delivery for first start. Ordered them the end of October, they are scheduled for delivery on 29 Dec.
    Installed charcoal canister, closed off all ports except one going to a vapor canister purge valve. This should keep any fumes out when parked in the garage. Currently purge valve is open when ignition is on, I may add a switch once body is on to allow fueling without the ignition on.
    Kill switch installed in glove box
    E-Stopp installed, works great and frees up passenger space.
  40. #35
    Where did you get the glove box?
  41. #36
    Feb 2017
    Lutz, Florida
    60's Kid,
    "Kraftee" dug his mold he created for his 33 out and made one for me, you can PM Eric and see if he still has the mold.
    I know he had his 33 up for sale and may not be on the forum any longer.
  42. Likes wrp liked this post
  43. #37
    Feb 2017
    Lutz, Florida
    First Start
    First start today - with new external fuel pump. I started it two weeks ago, however after about 10 minutes it stalled and would not restart. Internal FFR EFI fuel pump ran and pumped gas however no pressure reading on the fuel pressure gauge. I removed the in FFR tank fuel pump and added the external fuel pump that came with the Holly Sniper EFI.
    https://drive.google.com/file/d/1dvL...ew?usp=sharing
  44. Likes duff33, wrp, Mrallsport32 liked this post
  45. #38
    Senior Member JOP33's Avatar
    Haslet, Texas
    https://www.facebook.com/neil.wheato...type=3&theater
    Beautiful build! Congratulations.
  46. #39
    Jun 2018
    North Vancouver, BC, Canada
    Looks fantastic. Love the chassis colour and the wheels are great!
    The facebook link didn't work for me, maybe you need to change the video permissions to "public".
  47. #40
    Feb 2017
    Lutz, Florida
    Thank you, Could not have done it without this forum and all the great FFR members
    Please try this link
  48. Likes Mrallsport32 liked this post
