Base kit does not come with brake hose to frame brackets because it assumes a donor rear end and brakes. Complete kit rear brakes adds the bracket. BTW the bracket is better installed horizontally, (rivet to the top surface of the 3/4" tube), so the brake hose enters from below and forms a "U" shape. This allows the hose to roll more and twist less like it likes to do as the suspension goes up and down as the spindle turns. Also keeps the hose from pointing at the tire and wheel. I recommend changing the orientation before you do the hard line plumbing.
