Thanks Thanks:  24
Likes Likes:  101
Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 281 to 320 of 545
Thread: Yama-Bro's MK4 Build Thread - #9158 (Index in Post #1)
  1. #281
    Mar 2013
    Medway, MA
    Base kit does not come with brake hose to frame brackets because it assumes a donor rear end and brakes. Complete kit rear brakes adds the bracket. BTW the bracket is better installed horizontally, (rivet to the top surface of the 3/4" tube), so the brake hose enters from below and forms a "U" shape. This allows the hose to roll more and twist less like it likes to do as the suspension goes up and down as the spindle turns. Also keeps the hose from pointing at the tire and wheel. I recommend changing the orientation before you do the hard line plumbing.
  2. #282
    Kearney Nebraska
    Quote Originally Posted by Mark Reynolds View Post
    Mark, that's some good advice. Since I already attached the front brackets, I may leave it as is, but I can get what you are saying to work in the back. So I'll use your advice back there for sure. Thanks!
    Serial #9158
  3. #283
    Kearney Nebraska
    Last weekend I had another distraction that took me away from the build. It was Factory Five related and in my garage, so I figure it's worth a post in my build thread. The company hot rod spent the weekend in my garage so I could put BPE tire stickers on it. They turned out good. The BPE stickers are probably more difficult to apply then typical tire stickers because each letter/line that is a different color is an individual piece of rubber. That and these stickers are a little shorter font then the ones on my car, which made it even more challenging. As you may have guessed, those pieces don't always like to stay where they are meant to be, so there is some wrangling to get them in the correct location. I'm getting better at these the more I do them and I had a friend aiding with alignment on these, which really helped.
    As a bonus, I got to cruise around in the hot rod a bit. It was nice to see what driving a FFR hot rod is like. So far I've driven two FFR roadsters and a hot rod. I'm feeling blessed. The two roadsters were 3 link and the hot rod is IRS. The hot rod definitely rides smoother. It gets a lot of looks, thumbs up and waves, just like everyone reports when driving a roadster.
    I always dreamed my garage would have this many cool rides sitting in it at once...
    This is a steel bodied hotrod. We are still in the planning stages on the paint color...
    The powerplant in the hotrod is the BPE 306 with the Holly Sniper fuel injection and the TKO-600 transmission. This one is setup with AC. It doesn't have power steering.
    Serial #9158
  4. #284
    Kearney Nebraska
    Flexible brake lines...done...
    Here are the rear brake flexible lines. Factory Five sent me a a second pair of brackets for the rear. I used a 45 degree adapter on the calipers and 18" lines. I deviated from the suggested frame mount location by putting the bracket on the bottom side of the angled tube. Doing it this way doesn't require the line to flex and twist as much when the suspension goes thru its paces (like Mark suggested above. Thanks Mark!). Plus the line completely clears the suspension and wheels. I feel like I achieved elegance on this one.
    A view looking down from the top...
    A view from the back...
    I reworked the front brake lines. I wasn't happy with my previous attempt. I ended up buying some 14" lines and used straight adapters (vs the 18" lines and 45 degree adapters that were included with the brakes). These have decent clearance when the wheels are turned without having excessive brake line. This view is looking from behind the passenger side front.
    From the top looking down...
    This is the passenger side with the wheel turned fully to the left. I may have got by with couple inches less.
    This is looking down from above with the wheel turned fully to the right. The line is close, but has clearance. It looks worse in this pic than it really is.
    PS, I used loc-tite blue on the adapter threads going into the calipers and nothing on the 3AN brake line threads.
    Serial #9158
  5. Likes PeteMeindl liked this post
  6. #285
    BluePrintEngines's Avatar
    Nov 2015
    Kearney, NE
    You'll have to post all those pictures over on this one!
    https://thefactoryfiveforum.com/show...ight=blueprint
    Check out our crate engine offerings at www.factoryfiveengines.com
    Give us a call at 1.800.483.4263
  7. #286
    Kearney Nebraska
    I was pretty excited to get these parts in the mail. I ordered a pair of Girling reproduction brake reservoirs for an Austin Healey from Moss Motors in England. Since I'm going for a vintage vibe, I thought these would be perfect. There is a US version of Moss motors that carries the same part, but they had these on back order for several months. I bought the reservoir assemblies and the mounting clamps from Moss. I ordered a pair of 90° 4-AN to 1/4" barbed adaptors (p/n: 3488-04-90) from Pegasus Automotive in the states so I could connect the reservoirs to the hose that FFR supplies.
    I had to make a bracket to hold the reservoirs to the frame. I started by making a prototype out of cardboard. This felt a little awkward, as it's the first time in years that I've created something that I didn't design with CAD beforehand. HAHA. I've used SolidWorks for all kinds of home projects, from furniture, to sheds, to ATV parts. I considered using CAD on this, but for some reason decided to just wing it the "old fashioned" way. Maybe I wanted to show my kids how to do it the manual way? I don't know, but we had good results.
    Design notes based on others' posts on this forum: I measured back from the frame's radiator support tube 20", and then gave myself an extra 1" to have clearance for the hood support. I setup the reservoirs so the caps are a minimum of .25" under the top of the 3/4" frame tube. The edge of the caps are about 1" from the tube to avoid running into the body that overhangs the tube.
    I transferred the design onto a .125" thick sheet of aluminum. My son did the cutting and drilling.
    Here's the cut plate. We also made a support piece out of 1.50" x 1.50" x .125" thick alum angle. We cut one of the angle piece's legs down to be .75" long so it doesn't overhang the frame tube.
    We threw a coat of paint on them, so they match the frame.
    Here are a couple views of the mounting plate attached to the frame. We used 3/16 rivets to secure the parts...
    Serial #9158
  8. #287
    Senior Member cv2065's Avatar
    Dec 2017
    Those will look awesome!!
  9. #288
    Kearney Nebraska
    After the mounting brackets were attached, we assembled the brake reservoirs and attached them...
    Backside of the bracket...
    Serial #9158
  10. #289
    Chino Valley, Arizona
    Looks outstanding!
  11. #290
    Nicely done x 2. Love the look of those vintage cans. Also love to see a kid with a jig saw and not a game controller in his hand.
  12. Likes cgundermann liked this post
  13. #291
    Dec 2017
    Which fittings did you use for the bottom of those cans?
  14. #292
    Kearney Nebraska
    They are 3488-04-90, SKU: 55579
    Serial #9158
  15. #293
    Kearney Nebraska
    Looks outstanding!
    Thanks guys!
    Serial #9158
  16. #294
    Senior Member Dagwoods's Avatar
    Lavon, TX
    Build looking great. You mentioned that you positioned your bracket for the brake reservoirs 20" back from radiator support bar. Is that from the front edge of your bracket? I am looking to hang my reservoirs this weekend and would appreciate any advice.
    Andrew
    Mk IV base kit #9273 Delivered 1/29/2018
    3-link Moser 8.8 3.55
    TKO 600
    427w by Fordstrokers w/Holly sniper efi/hyperspark distro and ignition
  17. #295
    Kearney Nebraska
    Quote Originally Posted by Dagwoods View Post
    Andrew
    Hi Andrew! My measurement was taken from the backside of the radiator support tube. I also added approx 1" just to be safe, so it is more like 21" from the back of the support tube.
    Serial #9158
  18. #296
    Kearney Nebraska
    I connected the brake hoses to the reservoirs this week. We also got a good start on the hard brake lines, but you don't get to see pictures of those yet.
    I started by drilling two holes in the front of the foot box for the hoses to pass thru. The 3/16" thick steel on the other side of the aluminum made it more difficult than it needed to be.
    I added grommets to the holes. I got the grommets from McMaster Carr. I had to order 50 for $17 shipped, so if anyone needs some, let me know. If you send me a few dollars to cover shipping, I'll send some grommets to you. They are .50" ID for a .25" thick panel. They are made to fit in a .81" hole. I had a hard time finding a .81 hole saw or drill bit, so I ended up drilling a .75" hole and enlarging it a bit with the die grinder.
    Then I added the hoses to the grommets. I considered getting some black braided hose, because I don't like the way the red hoses look, but I figured these won't be super visible and I really should use some of the parts that came with the kit that I already paid for.
    An overview of the connections. I tried to line up all the fasteners so they are accessible once the car is finished.
    Serial #9158
  19. #297
    Member Scubasommer's Avatar
    Feb 2018
    NorthWest Indiana
    Looks awesome
    Super clean with the grommets brother!!!!
  20. #298
    Yama-Yo-Bro,
    If having a super cool, super bad Factory Five Hot Rod sitting as a stablemate to your build doesn't motivate you, then nothing will.
    You're Getting There Brother So Wrench On, Wrench On!
    Go-Dad / aka: Steve
  21. #299
    Kearney Nebraska
    Quote Originally Posted by Scubasommer View Post
    Looks awesome
    Yama-Yo-Bro,
    Go-Dad / aka: Steve
    HAHA, Thanks DUDES!
    Serial #9158
  22. #300
    Senior Member Pat427's Avatar
    New Braunfels, TX
    Really like those old school looking cans.
  23. #301
    Kearney Nebraska
    He we go; the brake lines. This is one of the parts of the build I wasn't really looking forward to. I ended up enjoying it. Thanks to my friend, Nathan, for the help (and refreshments). We now have the hard brake lines, bent, flared, and installed. Neither one of us had bent brake lines in the past, so it was a fun learning experience. Nathan convinced me to cut and flare the lines to the proper length, instead of making the pre flared lines work. I'm glad he did, because I think the final product turned out better looking because of it. Our only hiccup was that we accidentally did single flares instead of double flares the first time around. Whoops. It was a relatively easy fix. The real test will come when we bleed the brakes and check for leaks. We used my Dad's old school flaring tool and tube benders. I also used several pieces of wire to plan the routing before bending any of the actual tubes. I went back and forth between ni-copp and steel tube. I settled on steel, mostly because I figured I had better use some of the parts I already paid for that came with the kit. That, and I think it'll work just fine. Actually, I anticipated screwing up a few times and figured I'd have to buy some extra lines anyways. Surprisingly, that didn't happen. We managed to make due using only the tubes supplied with the kit.
    The boys trying out the tubing cutter. I didn't get a lot of help from the boys on this stage of the build. There was a lot of going back and forth and measuring and remeasuring. Not the type of thing that keeps kids interested. At least they got to mess around with the tools and some scrap tube.
    Here's the tube that goes between the front left and the front right.
    This is showing the tubes coming from the master cylinders, inside the foot box. The master cylinder that is closest is for the front.
    Here's a shot of the tube just forward of the foot box running down to the front brake tee.
    The tube for the rear brakes on it's way out of the foot box. (Edit: Check out the heat shield I built for this on Post #456)
    The bend in the tube at the bottom of the foot box as it heads to the rear brakes. I cleco'ed all these in this section because I still need to be able to remove the floor pan.
    Serial #9158
  24. #302
    Kearney Nebraska
    Hard brake lines continued...
    The run for the rear brakes going along the bottom of the car. We had one connection in this run to join together the two long pieces of tubing.
    The rear brake line coming up from the frame and going to the rear tee.
    The tee connection for the rear brakes (looking down thru the trunk floor).
    The line going from the left rear to the right rear...
    Overview of the line between the rear brakes. The line is attached to the frame in two places under the 45 degree angled tubes.
    Serial #9158
  25. #303
    BadAsp427's Avatar
    Greeneville, TN
    All of your bends look really great! The only thing I would possibly reconsider is your rear brake line that you have going down in the front of the foot box. You’re going to have headers literally 1 inch away from that line. I actually did the same thing and just relocated my line to the inside of the foot box this last weekend. Might want to consider doing the same. But I really like your Bends you did a fantastic job on those... nice work
  26. #304
    Kearney Nebraska
    Hmmm, yeah. I know what you are saying. I'm a little worried about the heat. The manual shows it routed on the outside, so I figured it would be ok (but maybe not?). I originally planned to run the line thru the footbox, but I couldn't figure out a good way to get it thru (at least where I wanted to run it). I even went as far as drilling a hole in the floor for the tube to pass thru. Do you have any pictures of how you routed yours around the accelerator pedal bracket and then up to the master cylinders?
    Serial #9158
  27. #305
    BadAsp427's Avatar
    Greeneville, TN
    Basically I came out of the top of the MC and routed the hard line over the front inside corner of the footbox. Then straight down the wall past the go peddle and through a hole that is right in the corner of the 4" and 1.5" frame tubing. You can see in these two photos if you look close what I'm talking about... as it went down the wall past the gas peddle I had to bend it out and follow the shape of the 4" tube to keep it nice and tight. It does not look like I'll have any interference with the use of the gas peddle as it is actually behind (in front of) the peddle when I'm at full throttle. The Red arrows are pointing at the rear line from the MC out... Hope this gives you an idea. Also, the photo shows where the headers fall in relations to the foot box.
  28. #306
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    John D. - Minneapolis 'Burbs
  29. #307
    Jupiter, FL
    Hi Yama-bro. I ran my lines inside the first time. I felt like it would look cleaner, and when I bled my brake I had 3 leaks, one in DS area. It was a mess to clean up.
    I also try to imagine the car fully assembled, that would drive my connection position and orientation. For easy access once the car is done. I am 1000 miles plus now, and it as a b*** to work on this thing!
    I have it just like yours now.
    Now, every time I park in garage I look underneath the car for leaks. It would be easy to spot outside leak vs. interior leak, IMO.
    But either way you run those make sure they don't leak
  30. #308
    Kearney Nebraska
    Thanks for the input guys. I'm trying to decide if I should change it or leave it.
    Broku, Do you have an infrared temp gun? I'd be interested to know what the temp is on the brake line after a drive. Or possibly worse yet, let it sit and idle up to operating temp.
    Serial #9158
  31. #309
    Jupiter, FL
    I don't. I ended up putting some heat shield tape in that area to cover the line.
  32. #310
    BadAsp427's Avatar
    Greeneville, TN
    I agree, you would not want a leak anywhere, but especially on the inside.... But running it like this, the only place you could have a leak on the inside is the same place, at the MC. Short of cutting or braking the line on the inside, but then again it is actually protected more inside than outside.... I guess it really comes down to personal preference and the actual amount of heat they get from being an inch or so away from the exhaust... while your moving it may not be bad if there is air flow there. I can not tell you how much air flow would be there as I have no idea from any sort of personal experience at this point...
  33. #311
    Dec 2017
    Agree with Carl. I have mine run on the inside. If you run a straight line from the MC down through the panel and then down the 4" tube, you can have a union right there. That way any leaks that happen would typically happen outside the footbox, unless you have a breach in the line somehow, but that would be on the inside both ways.
  34. #312
    Jan 2018
    Boiling your brake fluid sucks. Do whatever you can to limit the heat the brake lines see.
  35. #313
    Kearney Nebraska
    I asked FFR about this. Since they have a lot of experience building these cars and driving them I thought I'd get their advice. Their rule of thumb is brake lines should be a minimum of 1.5" from coated/insulated headers and a minimum of 3.0" from uninsulated exhaust. The ceramic coated headers fall into the insulated category.
    Serial #9158
  36. Thanks PeteMeindl thanked for this post
  37. #314
    BadAsp427's Avatar
    Greeneville, TN
    Oh, I totally forgot to put this on here from the other day... after my 1st run, i put the laser on the front foot box cover and after only the 10-12 minutes of running at idle, the foot box was 250* at the point where I had my line originally running down that area and yours is at just about the same place. The header there is about 1.5-2" away...
    Remember, this was sitting still, now air flow going past it... again, not sure how much you would get in that area behind the splash shield anyway...
  38. #315
    Kearney Nebraska
    Thanks! Excellent data!
    Serial #9158
  39. #316
    Kearney Nebraska
    I worked on the fuel system today. I installed the fuel pump and bent all the fuel lines. After a bunch of research, I determined that the fuel delivery system that came with the kit may not be adequate for the engine I'm planning to stuff between the frame rails (BPE 347, about 415 hp). So...time for an upgrade. I bought a Pro-M Racing fuel hanger, an Aeromotive Stealth 340 in tank pump, and moved up to 3/8 fuel line. This combo should be good for 600hp, which is way more than I plan to have.
    The Pro-M racing hanger has a 3/8 inlet and outlet, unlike the 5/16" outlet and dinky 1/4" return on the kit supplied part. Because of the bigger tubes, you have to enlarge the opening in the tank to get the hanger in. I used a die grinder to do do the cutting. I cleaned the tank out with a magnet and vacuum after the grinding was finished. Make sure not to cut into the groove for the o-ring.
    Here are all the parts I used. Pro-M Racing supplied everything to the left of the yellow butt connectors and Aeromotive supplied everything to the right. The butt connectors are water and fuel resistant. They came from Delcity.com, part number 922229. The tech guy from Aeromotive suggested using these ...Click Here . I had already ordered the delcity connectors, otherwise I may have ordered the Amazon ones instead. I'm sure it wouldv'e been cheaper. The tech guy said that's all he uses now-a-days. The Pro-M hanger came with a offset pickup screen, I used that instead of the centered screen that came with the pump. It seemed to line up with the box shaped baffle that's welded inside the tank. I really liked the connectors on the Aeromotive pump, but they are just so huge I didn't think they'd fit in the hanger, so I cut them off and put the butt connectors on the wires. The whole electrical wiring in a fuel tank thing makes me a little nervous. We'll find out if I did it right during the first start.
    The assembled hanger...
    The whole assemble in the tank. Don't forget to mark the in and out! A part I used, but it's not shown in the pictures above is the o-ring. The Pro-M hanger came with two orings with a rectangular cross section. I opted to use the standard round cross section o-ring that came with the kit. The rectangular o-rings go against everything I know about sealing. It's like putting a square peg in a round hole.
    Serial #9158
  40. #317
    Kearney Nebraska
    I took advantage of the nice weather today and rolled the body out of the garage so I could get under the frame and work on the fuel lines. I did some bending and tweaking to the lines that I had started bending a few weeks ago. Before it got cold again, I managed to get them mostly attached them to the frame.
    Here are the supply and return lines in the engine compartment. I went with Poly Armour 3/8 steel lines. I used four 40" pieces, part number PA-640
    The two lines running under the passenger side along the main frame rail. This is a picture from the back wheel looking forward. I didn't really want to, but I put a union in both lines down here. Hopefully it doesn't come back to haunt me later in the form of leaks. If it does, at least it's easy to get to. The unions are generic 5/8-18 inverted flare to 5/8-18 inverted flare that I picked up at my local Napa.
    Here are the lines as they reach the wheel well and go over the axle.
    A view of the ends of the lines looking from the rear axle forward. From here I'll connect flexible lines to the filter and the tank.
    Serial #9158
  41. Likes Higgybulin, PeteMeindl liked this post
  42. #318
    Very nicely done, Frank.
  43. #319
    Aug 2017
    Minneapolis 'Burbs
    2x... Very nice & clean install!
  44. #320
    May 2018
    Park City, Utah, USA
    Man, looks good, Yama-Bro! Great pictures, as always - makes it easy to follow what's going on!
