As Levy stated, your fuel pressure bouncing up/down 10 PSI means you have vacuum issues. Also, most high end distributors come with shutter wheels that are out of spec and bad HALS effect sensors. My new one did; the Ford OEM HALS effect sensor is the best and Pro-M racing sells an exact-spec shutter wheel. Replacing those and resetting my TPS cleared up my similar issues...
