Thanks Thanks:  61
Likes Likes:  415
Page 6 of 12 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 468
Thread: Black&Copper - 33 Hot Rod #1028
  1. #201
    Gatineau, Quebec, canada
    Got the final fit on the waterfall with the slots cut. While I continue with other things to get done, need to figure out an elegant way to fill in the slot and create a seal.20190221_224654.jpg 20190221_224645.jpg 20190221_224049.jpg
  2. Likes wrp liked this post
  3. #202
    Started setup on the arm rest for the center console. Going to wrap it in copper and use the same black rivets as I used on the firewall to put it together. Black and Copper! 20190223_211305.jpg 20190223_211301.jpg 20190223_214453.jpg20190223_214449.jpg
  4. Likes JimLev liked this post
  5. #203
    Ol Skool
    upstate NY
    Quote Originally Posted by AJT '33 View Post
    Nice work on the console! If your not putting a slot in the waterfall for the roll bars make sure you finish any wiring for things like power windows, 3rd brake, stereo etc. before final bolt in if you use the hardtop. The waterfall gets trapped by the other interior work also. I think the new HR changed the waterfall construction.
  6. #204
    Aj---going back to your doors, what were a couple of things that helped the most to correct the problem with the lower drivers door being out of alignment so far. I have the same problem and not sure what to do. A couple of suggestions would be very appreciated.
    Rick
  7. #205
    Quote Originally Posted by 60's Kid View Post
    Rick
    Hey RIck, I just happened to write this up on another blog where someone else was struggling to get the shell to line up to the body, here it is:
    Don't Panic. I ran into the same thing and after numerous attempts and calls with Tony, I finally figured it out and its not that hard, I'll try and describe the process and then hope this helps.
    1 - Fit the door shell to the opening without the supporting frame, this will allow you to ensure its alignment, don't worry about the alignment of the door face to the body at this point.
    2 - Once the shell is fitted (I kept minimal gaps), get the door support arm fit to the body with all the clearances, then remove it and get the slots in the door aligned so you can get the hinges into the door.
    3 - Follow the instructions in the book and other videos to get the door installed with the bear claw latch, DON'T install the strike pin yet.
    4 - OK, now using the four 1/2" bolts at the hinge side of the door, loosen and align the rear of the door as close as possible to the body, don't worry about the front at this time. Once aligned now your ready to adjust the front. The rear bracket that sits on the door can be connected to the FG door via a couple 1/4" bolts spaced far apart. This will also hold that alignment and make further minor alignment easier later
    5 - Now in the front, where you have the two 3/8" carriage bolts that connect the arm to the plate that's connected to the bear claw latch, dependent on if the top or bottom of the door at the front is misaligned, you will loosen these bolts and carefully add in spacer shims either above (BETWEEN THE PLATES) the top bolt to move (twist) the bottom of the door in or under the bottom bolt to move (twist) the top of the door in. This may take a few tries but be patient, it works and the fiberglass door is flexible enough to take the minor twist to it. Tighten the bolts thereafter to hold it all together (I added only a 3/32" shim on the top to pull the bottom of the door in and the top out splitting the difference and also getting better alignment to the body/frame as well.
    6 - Now go back to the rear and, if necessary, lossen either the top or bottom set of bolts to allow you to further move the door shell in or out as necessary. (This is where the two 1/4" bolts come into play to hold the shell to the bracket).
    7 - Now your ready to mark, setup and align the front striker pin.
    You may need to go back and forth a bit however once aligned when you pull the two rear pivot pins the door goes right back into its place. I know these are broad strokes of an explanation but its easy and it works, I just wish that I had realized this before trying to do the body work as extensively in some areas as I have done. This is also why i tell everyone one to get the body and doors installed and done first so they can cruise through the rest for the most part. I truly hope this helps, I will get some picks of the front shim I put in and edit the post, the doors now close with little to no effort
    Andreas
  8. Thanks JimLev thanked for this post
  9. #206
    Well moved along with the console and picked up my copper and started to mount it to the frame I built. Thank god for CAD and the ability to design something and then unfold it to be able to print it, takes out the guessing to get that perfect line. Now will be making the top frame and starting to mount it together. Once done will mount it and figure out how to mount the cover, will want to have it hinged. Will be mounting multiple switches on the angled face for various controls such as high and low beams, door unlocks and power windows.
    20190227_202612.jpg 20190227_202621.jpg 20190227_203226.jpg 20190227_202616.jpg
  10. #207
    Lots to post today, 3D printed my third brake light and inserted the light I bought from United Pacific Industries into it. Placed it such that the back of the housing will be flush to the hardtop as well as the soft cover when going topless. I will be snaking the wires through the back of the housing and under the hard top edge or the soft cover to a grommet in the middle of the hard top seal so you can't see them. Will be using automotive adhesive tape to mount the housing. After three randitions, the simple look ended up being the best one. Now to do some smoothing and prep work for paint!
    20190227_194602.jpg 20190227_195025.jpg 20190227_195031.jpg 20190227_195037.jpg
    20190227_195241.jpg running light intensity
    20190227_195244.jpg braking light intensity (if someone can't see that, they should not be driving!!)
  11. #208
    Well on to the next and possibly last major challenge, the suicide door safety latch. I was going to install an Autloc kit with the aluminum flat bar and pin but space in the door really sucks with power windows. So I packed up what I ordered and returned it ($300 USD) and will be trying another method which I can latch manually, for now, then figure out how I can add a single I will be designing a latch that will swivel on pivot and lock in place and hold the door. the fixture will mount under the dash close to where FFR mounts the hood latch handle, so I will need a lew home for that. I should be able to make it reversible so I can use it on either side. If someone has done something like this then please speak up as I would like to know.
  12. Thanks JimLev thanked for this post
  13. #209
    Got the copper console welded up, need to take some time this week and sand and polish it all up!
  14. Likes Mrallsport32 liked this post
  15. #210
    I need to figure out how to replace this switch for the headlights. It also dims the interior lights on the console. I'm not crazy about the look with the nut on the outside.
  16. #211
    Village Mills, Texas
    How about a headlight switch bezel from Summit, Amazon etc. Just a thought.
  17. #212
    Quote Originally Posted by HVACMAN View Post
    The question is which one would fit? I actually wouldn't mind as it needs to be marked however fit would be key, might drop a note to Tony Z and see if he he any info on them that got. THX.
  18. #213
    Placitas, NM
    I bought door poppers, don't think I can use them either.
    For door safety latches I'm looking at these.
    https://watsons-streetworks.com/prod...ety-lock-pins/
  19. Thanks Mrallsport32 thanked for this post
  20. #214
    Check out Ron Francis or Watson's street works. for light switch options.
    https://www.ronfrancis.com
  21. Likes AJT '33 liked this post
  22. #215
    I looked at those as well however what they don't show is the actuator and how wide it is when installed. With the motor for the power windows in the bottom front of the door, when that actuators is installed it would cover the PW motor. As well the pin may not be long enough to go from the door to the body which is also a problem. I ordered the AUtoloc version and ended up returning it. i would make sure you can return it if it does not fit correctly. I am working on a simple manual one for now and will most likely try and make it convertible to one using an actuator later, we will see.
  23. #216
    Placitas, NM
    I haven't got a far as installing the power window parts yet however I'm pretty sure the motor mounts to the lower rear side of the door. Let me know if I'm wrong.
  24. #217
    Your right, still thinking the traditional way of the way the door swings. Will be interested in how it works out regardless as there is a very limited amount of space in those areas and the length of the pin still may be an issue, may need lengthening.
  25. #218
    I tried installing the sliding seat racks in the 33. When I tried to install them it did not set it up exactly as they prescribe in the installation instructions, I am wondering others modified their track connections and where the track ended up? I am curious as when I set it up the 2.5" dimension works from the back of the rack for the rear mounting holes and not to the center of the existing mounting hole as in the diagram. As well when I set the seat down, I find that the bolting holes of the second to last crossmember is a better fit to have the seat as far back as possible with a forward travel of ~5". This however requires a new hole in the slider track as well. Would appreciate others experiences in the install and how they look under the foam seat. (sorry forgot to take pics, will add tonight)
    PS. did others need to add a 3/8" spacer so the seat frame does not sit on the slider handle?
  26. #219
    Placitas, NM
    Another door thing I just realized.
    There is no mention of putting drain holes in the bottom of the doors which might be a good thing to do.
    Water from washing the car and getting caught in the rain is sure to get inside the door thru the window slot.
    Seat sliders.
    I raised mine up, pics should be on my build page.
    See post 146, got them here.
    https://www.4wd.com/p/mastercraft-sa.../R-GNNN-620030
  27. Likes wrp liked this post
  28. #220
    Well got into wiring the last of the switch buttons and the relays in their relay boxes. As I changed out a lot of the switches that came from FFR. My son and I both dont like wiring however he is actually good at it!
    Andreas
  29. #221
    Definitely drill drain holes in bottom of doors.
  30. Thanks AJT '33 thanked for this post
  31. #222
    Well when you think your fine sanding theres another area that needs it. soldered the copper together and sanded it to 3000. Now I'll get some buffing paste and polish it up.20190319_205539.jpg 20190319_205544.jpg
    One small deep cut to fair out and then mark and drill for all the button switches.
    Andreas
  32. Likes CVOBill, Mrallsport32, Straversi, erlihemi liked this post
  33. #223
    Senior Member JOP33's Avatar
    Haslet, Texas
    Nice work! That is outstanding.
  34. Likes AJT '33 liked this post
  35. #224
    You know you must be getting closer to completing all the details when you start searching for details to finish!! Worked on adding some hidden space (well not so hidden since I am showing it here!!) to allow for some additional storage. Made the templates in cardboard the way I would want to make it out of 0.040" aluminum so I could simply use cardboard as a cut template. I sealed the outside and the inside joints and will be spraying it with gravel guard.
    My wife suggested adding some thin insulation and using it for a small cooler for sandwiches and "drinks" when we go on outings... can't say that's not a great idea!!
    Will be working out the attachment with a seal and that will be done. On to adding my windshield washer bottle and sprayer (found some really cool low profile sprayers, will get pics soon) with the hoses tomorrow and then the trunk and hood release. Once those are in I get the mirrors on and basically I will be good to do the last fairing of the body aaannnnnndddd... off to paint!!!!! (Can't believe I actually wrote that finally!!) Would really like to have everything painted and back in the shop by the Easter weekend. Crossing my fingers!!
    Andreas
  36. #225
    Continuing to make progress, got the rear trunk cable and latch in while I was prepping my third brake light housing I designed and 3D printed. Looks good just need a few touch ups and it'll be ready for paint.
    20190322_203229.jpg 20190322_203222.jpg 20190322_202721.jpg 20190322_102310.jpg
    Andreas
  37. Thanks peterh226 thanked for this post
  38. #226
    You get to a point in the build where you sit back and look at what you accomplished and say to yourself, damn my son and I did good!! You look at the car knowing that there was a whole lot of work that went into it so far.
    You then look around and feel good that you cleaned up the mess and look forward to a dust free shop. As I look around I then see the two sets of "TO DO" lists on the garage door and realize your actually close to the end... well almost!!!
    Spring is near and I can't wait to be comfortable enough to get the body and other parts to paint so we can clean up the rest!!! SOONER THAN LATER!!
    Andreas
  39. #227
    Jun 2018
    North Vancouver, BC, Canada
    Andreas, looking darn fine and just a couple pages of "to do" is indeed very close to the end! What will you do with all the extra time on your hands when you're done ?
  40. #228
    Enjoy it then start looking at possibly a 35 truck for the wife or a Ford COE to haul it if we do longer trips!!
    Andreas
  41. Likes wrp liked this post
  42. #229
    Progress and more progress, I hope all the prep work that my son and I are doing will pay off, I think it will. My son came by and did the testing of the wiring he setup and everything tested properly. Now to get the right size fuses and that should be good.
    Now to get the various templates for covers done and we should be good to pick off a few more items!
    Andreas
  43. Likes wrp liked this post
  44. #230
    Further progress and whittling down the list, got the big ticket item done in the fitting of the side windows. The fit was still tight even with the replacement windows from FFR. So I took a chance and decided to remove about an eighth from the bottom corners where it was too tight to my liking. After using my mini belt sander I was able to feather it down and still had a good solid feel to the fiberglass (I was hoping it was thicker as corners usually get over laminated and have thicker fiberglass) which seems to be the case in the areas I "adjusted".
    Before adjustment
    After adjustment
    20190330_113846.jpg 20190330_113857.jpg 20190330_113908.jpg 20190330_113915.jpg
    I will need to re-sand and primer those areas but my specialist can do that when he comes to do the final "smoothing out" with me.
    Further work on the list still to be done and currently on track to have it completed by the weekend so we can do final checks to be able to do the final body fairing next week then off to black polyurethane primer!
    Andreas
  45. Likes FF33rod, wrp liked this post
  46. #231
    Everyday closer and another challenge. As I have a hood that is made for the extra clearance, it is different than that of the standard hoods so it does not have the dual rib running down the middle. Now I have to figure out how to install the prop rod on this style of hood. Send a note to FFR so we will see what they come back with too.
    UPDATE: Well heard back from FFR and apparently the standard hood prop does not work with the raised hood. Tony suggested/says mounting it across the firewall as he had done on their flame 33 and others. They did it on their corporate 33.
    Andreas
  47. #232
    Well thought i was done with dust for the most part but no.... Oh well just means were that much closer to final primer before paint!
    Andreas
  48. Likes wrp liked this post
  49. #233
    SANDING IS DONE... for now... well once the base primer is on then I will still need to sand to 800 before base color then clear. Oh yeah, then will be sanding clear to 5000 then buff and shine, guess I am not finished after all but the "FUN" sanding starts now.
    20190413_140651.jpg 20190413_140642.jpg 20190413_140631.jpg 20190413_140616.jpg 20190413_140607.jpg 20190413_140559.jpg 20190413_140550.jpg
    Andreas
  50. Likes Mrallsport32, wrp liked this post
  51. #234
    Body rack modified for painting and transpotting the parts to be painted. Also made on for the hard top for painting and probably for hard top storage later. Got moving dolly's cheap for the base. Going to make a door cart as well.
    Andreas
  52. Likes wrp liked this post
  53. #235
    All ready to go for the last primer today!
    I even started cleaning the rest to see what it would look like under all the dust and got a little excited!!
    Andreas
  54. Likes wrp, FF33rod liked this post
  55. #236
    Well, went from Camouflage colored finish to a solid black base polyurethane primer, 3 coats, last night! Stressful to get to the point of painting but happy with the final result. Found some minor nicks and pinholes that should be easily taken care of with localized touch up before a full sand down with 400 and then 600 grit dry paper (may do a wet sand in place not sure yet). All in all a late night of painting (till 2am), but happy with the results so far. Now to get the sanding done and off to the base color coat and then the final 3-4 coats of Show klear from HOK.
    20190424_000512.jpg 20190423_235142.jpg 20190423_235138.jpg 20190423_222126.jpg 20190423_222118.jpg 20190423_222027.jpg
    The next couple of weeks will be hectic for sure!
    Andreas
  56. Likes FF33rod, wrp, JimLev, duff33 liked this post
  57. #237
    Looks Fantastic!
  58. #238
    Jun 2018
    Damn, looking good!
    Gen 1 '33 Hot Rod #1104
  59. Likes AJT '33 liked this post
  60. #239
    Everyone is home again!!
    Now to sand it all once I get back home from fighting the 100 year floods we are having here again!!
    Andreas
  61. Likes wrp liked this post
  62. #240
    Well, build has come to a screeching halt as I contend with flood waters at my home I own with my brother just west of Montreal. Seeing 100 year flood levels again this year like in 2017 but lasting longer to recede, this sucks and mother nature needs to take a holiday!!! Hopefully we will be able to get back to working on the The Mistress sooner than later.
    20190428_114954.jpg View of the front of the house
    20190430_161748.jpg View up the road (there is ~42" over the road)
    Andreas
