Thread: Ron Francis and Speedhut
    Question Ron Francis and Speedhut
    With the RF harness already in place do I need to run the Speedhut harness to the Speed Sensor and Fuel Level or can I just splice into the RF harness. . I see only one wire from the fuel level. I assume the other goes to ground. The Speedhut harness has two wires and I assume one is ground. If I connect one and ground the other will it work? If its best to run the harness fine thats what I'll do. I just don't know if there is a advantage to the extra wires.
    Director of Engineering, FFR Jesper Ingerslev's Avatar
    I don't have the instructions infront of me that come with in the gauge box but if I recall it says that one of the wires for the fuel level can get grounded. I will double check in the morning
    Jesper Ingerslev
    Factory Five Racing
    Just checked the instructions, use the wire in the Ron Francis harness and ground the black sender wire from the gauge.
    Jesper Ingerslev
    Factory Five Racing
    Thanks! Ithought it would be ok but I would rather ask first..
