Thread: New Compressor!!!
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    New Compressor!!!
    Black Friday special at local farm outlet store - score!!!!!
    Sixty gallon that'll serve up 16 cfm at 90 psi...... more than enough to run the blasting cabinet that is next on the list.
    Later,
    Mk3.1 #7074
    Senior Member RickP's Avatar
    Boyertown, PA
    The beast.
    Nice, but that sucker would take up 25% of my shop.
    Should do the trick for sure and then some.
    Wow. I wanted one of those, but it was out of my budget. Maybe next decade.
    Feb 2018
    Wee bit more bad *** than a little oil-less job
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Nice!
    Nice!!
    I've been running a V-twin 80gal for about 10 years now. Love it. Similar specs... 15+cfm@90psi all day long. A couple of things to consider...
    - When I rebuilt-remodeled the "40 Watt Garage", I took the compressor in mind, and built the end/corner of the main bench with the machine in mind. This corner was a "catch-all" for crap. I measured the footprint of the compressor, and have 4x4 posts/legs under the benchtop in these spots. The compressor is on the bench (!), sitting on 1" cork vibration pads, lag-bolted through the benchtop into the legs/posts. (Running, I can have a glass of water 5' away without a ripple... OK, a bottle of beer )
    - The other thing is routing the air intake(s) up out of the workspace into the attic. Relocate the intake filters up there. It cuts down on the noise by 50%+. No more LOUD "whumpawhumpawhumpa" in the shop!
    Just remember to have a flexible pressure line/union from the compressor to any "hard pipe" lines in the shop!
    John D. - Minneapolis 'Burbs
