Thanks Thanks:  225
Likes Likes:  220
Page 30 of 30 FirstFirst ... 20282930
Results 1,161 to 1,172 of 1172
Thread: Edwardb’s Gen 3 Type 65 Coyote Coupe #59 Build: 5,000 Mile Report
  1. #1161
    Quote Originally Posted by Fat Larrys Garage View Post
    Paul on your interior is that carpet from FFR or your interior shop
    Yes, the standard kit supplied Coupe carpet kit. I've used it on all my builds. Sometimes doesn't get a lot of love, but I've found it works fine. I always use floor mats and a pad by the accelerator. Will wear in the those areas but everywhere else seems to hold up fine. I tried a recommended alternative (Bentley) for one of my builds. But ended up putting it in the trunk as still used the kit carpet.
  2. #1162
    Apr 2019
    Hola Paul,
    I'm not good at these posts and maybe I shouldn't have put this post here but thought it might be close.
    I've completed my Daytona. My builder said it was easy. All I had to do was follow edwardb's posts and it all came out fine.
    Now I am fine tuning the setup for the track. I just did my first day with a professional driver in the left seat. He is a brave man to take out an unknown quantity and try and make it work on a race track, ECR (Eagles Canyon Raceway ten miles away).
    My car had terrible oversteer. I have installed the FFR front and rear sway bars. My drive buddy says we need to loosen up the back and tighten up the front. After our session we put the car on the lift and tried to move the rear sway bar back a couple notches but the supplied rod ends don't appear to be adjustable to reach. The front sway bar presently also does not appear to be vertical and the rod ends are also slanted a bit. The spacer appears to be too big.
    I know you don't track your car but your familiarity with all things Daytona I thought you might give me some direction on who to ask for set up issues with the sway bars.
    I did get a trophy in the car show at SVRA weekend at ECR thanks to your input.
    Best,
    Lou Garvin
  3. #1163
    Quote Originally Posted by Lougarvin View Post
    Hola Paul,
    Best,
    Lou Garvin
    Hello Lou. Congrats on your completed Coupe and award. Glad my build thread may have been of some use. You're right, I don't track my Coupe. Only on the street and the standard Factory Five sway bar setup isn't limiting me at all. (Or at least if it is, I don't know it. ) I can't give you any specific recommendations. I'd suggest you make a new post describing your situation. There are others on here with track experience and I'm sure could offer some advice. Good luck.
  4. #1164
    Feb 2018
    Half Moon Bay California
    Lots of Autocross and track days between Dave and myself and we will both tell you to ditch the rear bar.
  5. #1165
    Jan 2024
    Paul good morning I am looking into rims for the car more than likely going with Forgstar F14 I have been looking to do 18 inch front and 19 inch rear I see that you went 18 inch all the way around and your car sits nice does the 18 fill the rear wheel well and I believe you also used wheel spacers on the rear any reason for the spacers you you just wanted to push the wheel to the outside to look better
  6. #1166
    I have Factory Five rims. They don't offer 19's. So yes, 18's all around. The rear spacers are to push the wheels out into the openings for better appearance as you describe. The Coupe uses the same rear suspension setup(s) as the Roadster but the body is wider.
  7. #1167
    Jan 2024
    Paul do you remember if you got the oil filter new threaded adapter piece once you remove the oil cooler piece
  8. #1168
    When you remove the oil cooler, the long adapter must be replaced with a Ford AL3Z-6890-A Oil filter adapter (short). Got mine from Tasca Parts. But available from multiple sources.
    https://www.tascaparts.com/oem-parts...sert-al3z6890a
  9. #1169
    Jan 2024
    Thanks Paul your an ace
  10. #1170
    Apr 2019
    Hello Paul,
    Many thanks for your response and suggestion to figure out these sway bars and how to adjust them. It's a work in progress and I'm taking my time.
    Best regards,
    Lou
  11. #1171
    Prescott, AZ
    Hey Paul, got another question for you. I have been reading a thread where a Gen 3 Coupe owner is struggling with oversteer on his car newly finished car at the track. He is running both front and rear sway bars and struggling to come up with a configuration that is not tail happy. What did you do on you build, no bars, front only, or both? I checked the options box for both front and rear sway bars with the rear being the 2015 and up IRS. I have time to finalize my kit order, but it would sure be nice to eliminate the rear bar, or both, if they are truly unnecessary on a high performance street car.
    As always, thanks in advance.
    Alan
  12. #1172
    Quote Originally Posted by Alan_C View Post
    Alan
    My Coupe has the Factory Five bars on both front and back. For my driving, 100% street, I can't say I've noticed anything positive or negative about them. The car handles great and I wouldn't change a thing. But I'm a relatively conservative driver and zero track experience. So take that for what it's worth. One comment, and maybe you know this, but the front bars can be mounted after the fact. Easy. The rear requires two brackets that are bolted in as you build up the suspension. Even if you don't install the rear bar initially, you may want to get those brackets and install during the build. Saves taking things apart later.
  13. Thanks Alan_C thanked for this post
