Results 1 to 3 of 3
Thread: Repairs and a nice Russ Thompson upgrade on my MKII
    mburger's Avatar
    Punta Gorda FL
    I had a clunking noise in the right rear of my MKII. Even the 1 inch drop backing out of the garage I could hear and feel it. Brought the car to Rods Customs here in Punta Gorda and it turned out to be a bad right rear shock and a missing right rear upper control arm bushing. Had the shocks and control arms replaced and while there, they installed the Russ Thompson turn signal mod I had purchased a couple months ago. I had a joystick before for the turn signals. What a difference in driving pleasure with the RT mod.
    Mark
    Aug 2017
    Southern WV
    Looks great
    Russ makes a great product I installed one on mine and have been very happy with the way it looks and works
    Rick
    mburger's Avatar
    Punta Gorda FL
    Thank you.
    Russ is also a real good guy willing to answer questions and help as much as you need.
    Mark
