Thread: Is this the correct switch?
    Accord NY
    I am installing the RT turn signal and have the RF wire harness. I ordered the base kit so I do not have all the extra switches that come with the complete kit. F5 sent me this but I don’t believe it is the correct switch. Can someone confirm. I understand that if I use diodes I need a STSP and if not using diodes I need an STDP. Is the switch I have either one of these?
    Thanks Craig
    that is not a STDP switch. They sent you the switch they use for directionals.
    Accord NY
    thanks Mke
    I don't have the Russ Thompson setup in my car, so I'm asking out of curiosity. Doesn't the Russ Thompson setup replace the turn signal switch?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Craig,
    You have shown the ON/ON switch that is used for the headlight high and low beam selection.
    Papa,
    Yes, Russ' setup replaces the turn signal toggle switch.
    Jul 2017
    Quote Originally Posted by cfriedman67 View Post
    Thanks Craig
    I used a regular on off switch with diodes purchased from ebay, easy to do.
