46
277
JimLev
Thanks wrp.
Haven't had much spare time in the last week to work on the car.
I started to do the exhaust which will require cutting and welding due to the BBK headers not aligning with the FFR pipes. I worked on that for a while and then decided to go back to the electrical.
Hey Jim, take a good look at the BBK headers, after successfully getting our first start we soon discovered that the headers were leaking exhaust right inside at the plate of where they all connect together, I get a distinct hissing as well as blow out from in between. So if you have not yet installed your headers or their easily removable, inspect them and if possible plug the four pipes that go to your engine and use a shop vac in reverse to pressurize the exhaust end, you may find that they also leak. I will be contacting FFR to see what they want to do as there is NO WAY of correcting this.
