I finished installing my new head gaskets this weekend. I must say that I did not enjoy having to pull the engine apart in a finished car but it does feel good to have done the work myself.
I have read several posts by others stating that head gaskets do not fail without reason. In my case I was not able to identify any cause for the failure.
The engine has not ever over heated. The coolant leak was to the outside of the engine and not into the cylinders. I did not have oil in the coolant nor coolant in the cylinders.
I took the heads to my local race shop. JGM Motorsports. The heads were nearly perfect with exception to a little brinelling from the head gasket rings. I went ahead and had them surfaced, cleaned and leak tested.
The owner of the shop was kind enough to come to my house and inspect the engine block. He said all was perfect and complimented me on my prep work for the new gaskets.
The only other thing I found to be odd was that the head alignment dowel pins were in pretty rough shape. I showed them to the race shop and they were not surprised but that I should replace them.
I only have 25 miles on the engine after replacing the head gaskets. The engine only has 2600 miles on it altogether. Hoping that all is perfect now. Fingers Crossed.
